To OutofTouch, A Request.
I just picked up the Top Model Bundle and am very happy with it, I really like the hair for an ongoing character, but none of your genesis 3 hairs with a side part have a mirror version. If you do another hair with a side part for G3/G8, can you please add a mirror version? Or possibly update Emilia hair or Jolina hair with a mirror version.
Thanks.
  • Cris PalominoCris Palomino Posts: 12,959
    I'm not sure I've ever seen OOT in the forums, so if you really want to get a message to her, put in a ticket.
    edited August 2017
    Also, hairs designed to have a part would probably end up having to be a different model.  It's not like real hair that you can restyle.
    Post edited by Cris Palomino on
  • BurstAngelBurstAngel Posts: 768
    I know, I was trying to find a parted hairstyle for both an updo and long length. Trying to find different hairstyles that "goes" together is a pain and a real drain on the wallet. Couldn't hurt to ask. Thanks
  • LindseyLindsey Posts: 2,017
    To flip a hair horizontally, set the hair's  X-Scale to -100
    If you only see a Scale parameter, select Show Hidden Properties on the Parameters Tab Pane Options and hopefully it will display.
    See attached pictures of Morley Hair with the hair/part flipped.
    537 x 453 - 87K
    667 x 647 - 203K
    Wow, That actually works! Thanks:)
    Good to know. :)
  • VueiyVueiy Posts: 608
    Yeah, I've been using that trick for awhile now, lol (like on a pair of mirror twins).  One note for anyone trying it the first time: the textures may not appear correctly (mine appear black, but that might just be my computer...?), so you should probably apply the textures and/or shader that you want on it first and do some test renders to get it right before flipping it.
