Zeroing figure pose etc
Trying to get my head around the ds4 interface. Is there a quick way to zero a figure pose? I can do it via edit, then figure, then zero, etc. But in ds3 there was a really quick option in the parameters tab, and I can't find it if it is there. Partially, I am wrestling with there being so many darned panes to navigate.
  • barbultbarbult Posts: 26,593
    edited August 2017
    See attached screenshot to access the Parameters Pane menu.
    777 x 489 - 190K
    Post edited by barbult on
  • ChoppskiChoppski Posts: 646
    Thank you!
  • cm152335cm152335 Posts: 421
    edited August 2017
    you can added manualy to order ZERO (RESET) POSE on your toolbar
    via the 'F3' check on >"parameters" command and move it to the >toolbar
    also any other command you want fromthe list or custom actions
    1618 x 1000 - 252K
    Post edited by cm152335 on
  • Great hint cm152335. Thank you very much. ...before I made a shortcut for it.
  • marblemarble Posts: 7,500
    I added a keyboard shortcut for (CTRL-Shift Z) Zero Pose because I use it so often. A reminder: keyboard shorcuts can be configured thus:
    Window > Workspace > Customize (or just F3 will take you to the Customize panel)
    Select a function from the Left Hand menu (click on the + of Parameters for the Pose functions) and then Right-click it to set or change the keyboard shortcut.
