Make Towel Look wet
Does anyone know how to make a towel thats wrapped around someones body look wet like they just got out of the shower?
  • nonesuch00nonesuch00 Posts: 18,863
    I would add translucency but not too much.
    In Photoshop I'd darken the wet areas and add or draw water droplets on the skin and around the damp affected areas
  • father1776father1776 Posts: 982
    Well, if you got PS this will be a bit easier
    adjust this suggestion as required
    hit the towel with med. gray - about 80% transparent
    blend out the towels natural texture a little, just a touch
    stretch the towel a little in the direction of gravity...give it a bit of water weight sag on the bottom edge center
    add a little water on the floor under it and the deal is done.
