Does Genesis Supersuit work with 4.5 Pro
trestudiostrestudios Posts: 0
This may sound stupid, however, I'm interested to find out if the Genesis Supersuit will work with DAZ Studio 4.5 Pro. Because I found this under Compatible 3D Software: Daz Studios, and since there's another search for 4.5 Pro, I wouldn't want to get the software, and then find out it doesn't work with what I have.
Also, is typically anything that is Genesis, will work with 4.5 Pro?
Sorry, I'm poor, and I worry a lot. Thanks ahead of time to anyone who answers.
http://www.daz3d.com/genesis-supersuit/
    Yes, anything DAZ Studio will work in DS4.5, the other way around doesn;t work, when it says DS4.5, that is what it nedds (or later)
  • Scott LivingstonScott Livingston Posts: 4,352
    Yes, the Supersuit and its accesories work in DS 4.5 Pro.
    You're correct, typically any Genesis product will work in the latest version of DAZ Studio. I'm not aware of any exceptions to this (if there are exceptions, I would expect that they are errors that should be corrected). There are at least a few products that don't work quite as well in DS4.5 as they did in DS4.0, for example: Short Beard for Genesis (there's a fix for it, but it's somewhat complicated: http://www.daz3d.com/forums/discussion/10457/)
    Some plug-ins for DS3 won't work in DS4.5...Light Dome Pro 2 comes to mind.
  • trestudiostrestudios Posts: 0
    Thank you, JimmyC_2009 and Scott-Livingston!!
  • JaderailJaderail Posts: 0
    Other Plugins to Avoid are...
    Mood Master and Render Throttle.
