Luxus discussion
Adding to Cart…
I had perspective off on the camera, no idea why. Turned it back on and it's rendering perfectly now. Thank you!! and thanks for making this product so more of us can use it!
Glad its working for you.
If its the same as Reality if using M LIE textures once needs to use collect textures.
You can name lights differently and they show up as light groups. At the moment this does only work if the nodes are named differently (as the node name is used as light group name), but that will change to add the surface name - then you can have multiple light groups per node.
Sounds like it more or less works the same will read the manual as I say as a Lux fan its good to have options..
If you guys are curious to see my many many Luxrenders http://bobvan.deviantart.com/
First of all, please forgive my ignorance and if the answers have already been given elsewhere. I am somewhat new to LuxRender not having fully explored Reality but.
1) Are the shaders we have collected useless or merely take a little tinkering in Lyux?
2) What about texture, displacement, bump, and opacity maps?
3) Do lights from, the Reality set work in the new Luxrender/Luxus system?
Thanks for your answers and assistance.
All I wish to know is...where's the manual or user guide for this plugin?
I don't have Luxus, but I assume it's similar to Reality when answering your questions:
1) Custom shaders built on Shader Mixer or Shader Builder are pretty much out, since those rely on Renderman stuff that LuxRender doesn't support. Shaders that use one of the standard DAZ Shader types, though, and are built on things like tiled textures should be convertible.
2) LuxRender supports bump, normals and displacement. (ProTip: convert bump maps to normal maps for LuxRender -- they work much better.) Opactiy is done by mixing one material with the null material, which I'm assuming Luxus takes care of generating for you, just as Reality does.
3) What lights specifically do you mean? From what I've seen people posting, Luxus lets you convert any surface into an area light, just like Reality does. If you mean you have, say, a Reality MeshLight loaded and you want to render with Luxus instead of Reality, it should be possible to just have Luxus apply the area light stuff to the Reality MeshLight object and away you go.
1. Yes/maybe...since Lux and 3Delight don't speak the same shader language, they (materials/shaders) aren't directly usable in the other. But this plugin will do most of the heavy lifting when converting them, same as Reality or the old LuxRenderDS plugin did.
2. See the second half of answer one...
3. Not sure...someone who has both will need to answer that.
The basic Lux materials cover a lot of those gaps and this like the others will allow you to access those materials. Plus there is a beta plugin for ShaderMixer to get even more fun stuff going...
Hello,
Purchased this today and been playing around quite a bit with it. I think it's a solid first iteration at ntegrating LuxRender into DS, but isn't exactly for the faint of heart. ;) (To be clear, the auto-conversion and push button render go a long way, but to get awesome looking renders you need to put in some time to learn how Lux behaves just like what works well and doesn't in 3Delight.)
I've learned a lot about Lux today coming at it as a total newb. I did have some questions around features that are either there and I'm missing (quite likely) or maybe have to be achieved outside of DS itself.
While playing and learning about all the render types, I see that sppm is listed as a renderer option, but I don't have sppm listed in my dropdown of surface integrators and therefore can't get it to work. I didn't see any sppm options under the surface integration options list either, so I'm thinking maybe this isn't supported yet?
I also wasn't able to find settings for rendering accelerator or SLG rendering anywhere?
And if you don't have the option to split the set up into parts? Then what?
By node I'm guessing you mean the Set or prop in question?
-Paul
Perhaps I put the option in the wrong spot, see attached image?
Full disclosure, I have not tried the ssp option.
I read somewhere that there are tiling issues? I will prolly wait till it's resolved. Im one of those who simply wanto to use the plug in. I dont know how and dont want to have to bother editing the xls files manually....
Well, I need some help here. Just a starting point. If I render with the surfaces as they are set by the DS preset, the image renders very acceptable in my opinion. When I load the Lux Material with Copy Studio Parameters ticked and send the render to Lux I get some annoying dark areas. I played with every parameter in the Lux Material section and cannot rid this effect. What I am doing wrong?
Only the Torso surface was modified.
On geometry like a figure's skin surface, you would certainly want to do all the skin or none of the surfaces manually.
But that does not answer you question directly. Perhaps you could screenshot your LuxRender parameters?
And you already did. Sorry. Let me do some research.
You probably want you URoughness and your VRoughness at around 0.8, your skin is so smooth, it is reflecting like a mirror.
Hum… It is there, but I am uploading again.
You probably want you URoughness and your VRoughness at around 0.8. Your skin is so smooth it is reflecting like a mirror.
Spheric, I don't know if anybody's asked this, but is instancing supported? In other words, If I make 8 copies of a 100K polygon tree, will Luxus recognize that and export only a single geometry, or will it spit out 8 identical copies of the same tree?
And if instancing isn't supported, let me be the first to request it.
Already supported.
It dont matter that much since I have Reality I can always till it goes back on sale or better yet fastgrab..
maybe its my PC but it takes eons the luxrender console inside Studio, no render at this time, ironic that I've been a maxwellRender and Modo601 user and Reality 2.5 and can't just make a render inside daz with Luxus...I'm old [ taking a time reading the PDF instead]
Oh, I've found it, my figure was in High Resolution Level 2, I must turn it off.
I snapped it up (already having an unused LuxRender install helped me to it...) because Reality was always out of budget and Luxus promised to actively integrate into the Render Settings tab: that's why the free-DL LuxRender export plugin has not been touched. If I don't have to do any program-hopping, I don't plan to. Thanks for this!
The roughness parameter does not solve the issue, but I removed the bump map and this worked. So I set the bum map again, but at a very lower value and the problem gone away. Much better now…
Hi Spheric,
Thanks a lot for the quick response! I can select the option you highlight, but Lux errors out because it expects a surface integrator for sppm as well in order to for the render method to work. I think what is needed is an option for sppm here as well. Whenever I try to render with sppm with any of the current surface integrators I get an error:
Hope that helps you figure out what I meant!
Hi Spheric,
Yes, SPPM requires the 'sppm' surface integrator...that should be one of the options listed in the Surface Integrators drop down. So will it be added in the update to fix the tiling? I use SPPM a lot...
Sounds like a good plan.
Hi Spheric,
