Any way to make the spot render tool ignore scene lights and just use the headlamp?
cwichuracwichura Posts: 1,042
When testing normal and displacement maps, it's much easier to see the results in the spot rendering tool when it just uses the headlamp and not any scene lights. Usually I don't have any lights loaded when doing this, but occasionally I'll have things like a point light in the bulb of a staff that one of my saved-for-reuse characters is holding. The point light means the character itself will be very dark, since it's not really meant to illuminate the scene. The viewport lets you turn off scene lights and just use the headlamp. But I've not found a way to make spot renders do this, short of deleting all lights from the scene, which is a nuisance as they then need to be re-created. Setting the lights visibility to off, turning off their node in the scene list, setting their illumination to off, etc doesn't make any difference to the spot rendering tool.
Anyone know of a trick to make the spot rendering tool use the headlamp without having to delete and then restore all lights in the scene?
Thanks
  • JaderailJaderail Posts: 0
    Not an Option I'm afraid.
  • BlackFeather1973BlackFeather1973 Posts: 739
    That sounds odd, turning the lights off should spot render a black rectangle (it does for me).
    You could parent a spotlight to your camera, wich would mimic the preview headlamp in your spot renders.
    Right...if the lights are off, it should be black...unless there is some ambient color and strength. set...
    896 x 923 - 221K
  • Richard HaseltineRichard Haseltine Posts: 110,877
    edited March 2013
    What you can do is this:
    group all of your scene lights
    in the Property Editor create a new property for the group called One (right-click in the property list on the elft of the pane) - set it's min and max and default and value to 1, lock it and hide it. Now Drag that into the Controllers list for the group's visibility
    Create a new light, parent it to the camera
    Select both the light and the group of other lights
    In Property Editor drag the Visible property from the list of properties onto the Visible control for the group, under controllers - DS will tell you it didn't create a link for the group, that's OK. You should now see both the One control and the Visible control from the head light listed under controllers. select the Visible control, and in the settings area set its ERC type to subtract. If it all worked, when you click to make the head lamp visible the scene light group will be turned off and vice versa.
    731 x 953 - 82K
  • cwichuracwichura Posts: 1,042
    edited March 2013
    Well, obviously it makes a difference in that you get a pitch black render. But it doesn't make Studio fall back to a headlamp render, which is what I am after. And yes, there are hacks to work around this like parenting a spotlight to a camera, but that's an extra step and requires an actual camera when often I'm just working in perspective view. Anyway, I submitted a feature request to make spot renders use the headlamp when the scene lights are turned off in the viewport (CTRL-L option).
    Post edited by cwichura on
    Sounds like a good one...
    edited March 2013
    n/m
    Post edited by BlackFeather1973 on
    Thanks
    Hi cwichura, fixed that for ya.
    Now you can do that in Daz Studio : Daz Studio HeadLight Simulator Script
