Movie blurry movement in daz animations
There is any option to make the movement of a character more "blurry" while animating in DAZ like the movies? See the example in the image attached please. Thanks
  • I found this animation on Youtube
    What I'm trying to do is making the transition between movements more soft/blurry like the movies. I tried with 15/24/30/60 fps and tweak every option in the camera but I can't make this effect. I use iray
  • The animation above doesn't have it. I have attached a image showing what I'm trying to achieve when a character is moving fast
    1024 x 425 - 63K
    Not sure but you could try a very narrow depth of field where the camera stays focused on the eyes very narrowly or not focused at all but just follows the action.
  • DekeDeke Posts: 1,636
    The easiest way to achieve a motion blur is to add it in post through a program like After Effects. I'm not even sure the depth of field choices in Daz Studio will add motion blur.
  • rames44rames44 Posts: 336
    One thing that comes to mind is that if you created a very short animation with the appropriate portions of the character moving and rendered it out to N frames, you could then post process the frames together using Photoshop, GIMP or equivalent by "averaging" the frames together.  The non-moving parts would end up crisp because they'd be the same in every frame, while the moving parts would look blurred as a result of the frame-to-frame differences. Granted, that requires more than just Daz Studio, but...
