How should I set instancing optimization for Iray
Windows PC 16gig ram 4 gig non-Nvidea quad core card. Should I set for memory or speed? Thanks in advance
  • If your GPU isn't nVidia then it isn't a factor, you are using the system memory (and CPU) so going for speed would probably be the first choice, try memory only if that fails to render.
  • NormNorm Posts: 71
    Once again Richard, thank you bro.wink
