Really Weird Glitch
Fae3DFae3D Posts: 2,867
Ok, I have a really strange problem.  I'm almost finished with a file I've been working on for a week, and go to render it. Everything renders fine, except for transparencies - anything that I had turned opacity down or off of in the materials is showing up full opacity.  Not in the workstation, only in the render.
I tried saving and closing Daz.  Restarting computer.  Deleting the items and adding them again.  No change.
Has anyone else ran into this?  Is there a setting I have accidentally changed somewhere perhaps?
My stats are Mac OSX 10.11.6, DAZ 4.9.4.117 Pro 64 Bit, 3Delight.
Any ideas would be amazing, this one really has me confused!
  • 3Diva3Diva Posts: 11,981
    That's an odd issue. I don't use Mac or 3Delight, so sadly, I can't try and find the problem. That's very weird though. I hope someone is able to help out. I know that sometimes Mac isn't as supported as Windows, so I wonder if that might be part of the problem? I hope you're able to get it worked out.
  • Fae3DFae3D Posts: 2,867
    Thanks, I hope so too.  I've been using Daz on my Mac for years, and I've never run into this problem before.  If no one has any ideas, I guess I'll open a ticket for it.  Those take awhile, but maybe it'll get sorted that way.
  • scorpioscorpio Posts: 8,533
    It might help if you posted some images of whats happening and a screen shot of the surface settings for the items that are causing a problem.
    Also what lighting are you using?
  • LinwellyLinwelly Posts: 6,067
    adding to what scorpio said: what set did you use ( all changes in the opacity coming from the same set?), as well just add a simple sphere to your scene and change opacitiy on that to see what happens
    Ok, sorry it took so long, but I found a solution.  I used the "Reset Surface" utility on the offending items, and then changed opacity to 0%.  For whatever reason, that fixed it.
    I think the materials I was using may have been Iray materials originally that I had used 3Delight shaders on.  So I guess maybe something went wrong with the conversion from Iray to 3Delight.
    Thank you, everyone, for your help!  ^_^
    edited August 2017
    I'm glad you found the solution. :)
    Post edited by 3Diva on
