Faveral ship comparison
I need a detailed ships deck for a project and looking thru the store, the best bets seem to be the Faveral ships, Does anyone that has both the Licorne and Medusa care to chime in with info on the deck details, maybe a couple of deck renders to compare, etc. It would be appreciated
  • IvyIvy Posts: 7,165
    I have the medusa in an animations the camera has a pretty good look around at the deck
  • DaWaterRatDaWaterRat Posts: 2,887
    They're more or less the same ship, actually.  Same model, anyway.  I prefer the Licorne/Aurorae, because the wood texture on the Medusa can show its age, and the UV mapping isn't as granular as I'd like to use shaders, but otherwise they're both fairly well detailed.
  • FaveralFaveral Posts: 416
    Licorne and Medusa have pretty much the same deck. Licorne has more details in the quaterdeck. Licorne also comes with two different sets of materials both for the ship and all the deck props. Licorne has more deck props than Medusa (in the Licorne Accessories set). Medusa is based on Licorne, only it has been made less ressource intensive by reducing some of the poly heavy details, reducing the amount of separate props and changing standard texture maps by tiling maps when possible.
    If you are looking for more details, I'd go with Licorne and Licorne accessories.
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Thanks all, much appreciated!
