Look at My Hair/Garibaldi Express Hair System
First, I recently bought LAMH, though I haven't used it yet and realized (much too late) that I never found out, does it work with Reality render? I only use DS if I use that so now I could kick myself.
Secondly, is there a post in the forum comparing the two products? I thought I saw one but evidently the search is not working because even when I type in "Garibaldi" it turns up no results. I'm wondering if I should go ahead and buy the GHS or if it is pretty much the same thing.
From what I understand from the bit I remember reading that you can export the hair for use in Poser? or that you could do it to use Reality?
You can export object files from both.
Comparison thread: http://www.daz3d.com/forums/discussion/17345/
Thanks.
Ok, is export though what you have to do to render it in Reality/Lux?
Yes to use with Reality both Plug-ins needs the Hair exported making it real geometery as opposed to Renderman Curves inside Daz Studio which are't geometery at all. :)
