HELP: iRay in Viewport ignores convergence settings
Could anyone open DAZ Studio, leave the scene empty and turn on iRay in the viewport? Could you then post your log file from the last point where it says "rend info : Rendering..."? I'm trying to see if I'm the only one experiencing this problem.
When I turn iRay on in the viewport, it completely ignores the convergence settings and renders 5000 iterations even on an empty scene. Max Samples and Max Time work, but not Rendering Converged Ratio.
I believe that's because it obeys Draw Settings and not Render Settings. I could not find a setting for convergence under Draw Settings...
Hope this helps!
There's a setting to blend from Photoreal or Interactive to Render Settings. Still ignores convergence. Does this happen for you too?
