Features that you could slap yourself for not figuring out sooner.
vrba79vrba79 Posts: 1,483
edited July 2017 in The Commons
I just figured out that distance lights can be parented to cameras.
...I've been using D|S since Genesis 1 came out...and I'm just now figuring this out.
Anyone else have a similar moment?
Post edited by vrba79 on
«1345678
  • DaWaterRatDaWaterRat Posts: 2,885
    Better still, you can look through distant and spotlights (select from the camera dropdown) to "see" their position...
  • nonesuch00nonesuch00 Posts: 18,773
    Oh, that is nice
  • Depth Canvases.  :)
  • xyer0xyer0 Posts: 6,353
    Depth Canvases.  :)
    @Digital_Lite_Design could you elaborate please?
    When I first started ds I didn't know I could make my own camera. I was constantly frustrated because I would save and the perspective view would be altered and I would spend hours putting perspective back lol!
  • BlueIreneBlueIrene Posts: 1,318
    edited July 2017
    Lots of things, especially things I briefly knew once, went 'Oooh!' about and then almost immediately forgot. The one that still niggles me a bit is grappling with the geometry editor, realising it would have solved so many problems when material zones weren't enough for my needs, then giving it up as 'too difficult'. I warily returned to it about a year later only to find that it held no difficulties for me at all. Maybe I was just 'ready' for it by then. I use it all the time now - editing material zones is as quick and simple as editing an e-mail.
    Another 'why haven't I been doing this sooner?' thing is adjusting hair when trying to fit it to a figure before parenting. Viewing it in wireframe mode was the best I could come up with to enable me to see what I was doing with the scalp, until the day came (after many months of doing it in this dopey fashion!) when I realised I could select the material zones of everything except the scalp and hide them, quickly adust the hair (the scalp of which is now clearly visible) then bump the opacity of the material zones back up again. D'oh! :)
    Post edited by BlueIrene on
  • AlienRendersAlienRenders Posts: 798
    You don't need to parent an item to have it fitted on a character. This is necessary for fbx exports where you only want to export the figure and certain items. If an item is parented, it won't repect that item's visibility state if you export the parent figure when exporting to fbx.
    If you want to set your own Sun location when using Sun-Sky setting, just move your camera to where you want the Sun to be. This way, you'll get a good view of what angle you're illuminating your scene. Then create a new Null object and select the option to copy the viewport's transforms. Now set that null object as the Sun node in the Environment settings. Move the camera back to its proper location. You can now move the null Sun node later if need be. You can use this technique to position all sorts of things. New cameras, lights, etc. If the option to copy the viewport's transforms isn't there, create a camera or null and parent the new item to it.
    Smoothing surfaces in problematic areas can sometimes be done by lowering the smoothing angle instead of increasing the subdivisions. Not sure if it alters rendering times, but it certainly uses less memory.
  • zombietaggerungzombietaggerung Posts: 3,855
    I had no idea you could do this with the Sun/Sky. This is BRILLIANT!
  • Seven193Seven193 Posts: 1,146
    You can hide lights and entire characters with groups.
    Create -> New Group.
    Parent character/light to group.
    Hide the group, and everything under it disappears.  No need to uncheck a dozen checkmarks to do it.
  • nicsttnicstt Posts: 11,715
    Local Camera Dimensions.
    Cameras > Dimensions > Use Local Demensions.
    Great for producing a smaller (or larger) render resolution than the scene is set for.
    F3
    Customise Daz Studio
    I use it most often for customising the scripts menu.
    F3 > Menus Tab > click the Main Menu then Scripts plus (+) symbol.
  • Oso3DOso3D Posts: 15,090
    That reminds me... can someone explain what smoothing angle is/does?
    I have been wishing for ages that there was a way to bring more order to my chaotic scripts menu! Sorted - thank you :)
    nicstt said:
    F3
    What Will said /nod
    nicstt said:
    F3
    Welcome. I'll pass your thanks on to Richard; he responded to a post I'd made. :)
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Discovering custom actions (right click on the item and it goes to the scripts drop down for quick access) was a huge time saver for me with items I use often. Can't imagine not using it now.
  • j cadej cade Posts: 2,310
    edited July 2017
    Ooh lets see if I can explain this semi-intelligibly.
    First thing: It might help to think of smoothing as faking subdivision
    The difference between smoothing on/off is easier to explain.
    Smoothing off will make meshes look faceted, every edge is hard, very evident corners between every mesh (think of tour mesh in wireframe mode imaging all those lines as sharp), It can be useful for doing things like gemstones very low poly.
    Smoothing on and angle set to 0 tells the render engine "nope it doesn't matter what the mesh looks like try and pretend its smooth" of course since this is an approximation if you have a very low poly mesh with sharp angles and smoothing all the way on you can run into artifacts.
    Smoothing angle tells the engine at what point to pretend the mesh is smooth. If its set to 0 than everything is smoothed If its set to 89 (the default) than the engine will treat any faces that come together in a right angle or smaller as hard edges and any obtuse angles as smooth.
    and because a picture is worth a thousand words:
    Faceted
    Smooth although this low poly you get some weirdness,note the silhouette , and shadow terminator problem
    400 x 400 - 46K
    400 x 400 - 43K
    Post edited by j cade on
  • L'AdairL'Adair Posts: 9,479
    I just learned a new one today, watching a video by Sickleyield.
    In the sene tab, if you select multiple bones that move in the same direction, (for example the left and right foot bones of a figure,) then in the parameters tab, also select the same, you can move them at the same time.
    I've been using the Geometry Editor for maybe a year, and I only just discovered Selection Sets. Now if something is only temporary, I assign it to a set and I don't mess up the surfaces!
  • Daz Script.
    Daz Script.
    laugh
  • RGcincyRGcincy Posts: 2,862
    I recently discovered push modifiers - very handy to make large/small changes to geometry
  • Used to think DOF was something only Octane users could use, until someone explained how to use it in DAZ.
  • RuphussRuphuss Posts: 2,631
    nice thread
  • mcorrmcorr Posts: 1,104
    edited July 2017
    forget what it's called, but it's a node, decal or something where you can -- for example -- make a wall in a room invisible and then with a camera outside the room look inside the room without the outside lighting affecting how the camera captures how you set up the lighting in the room. this can be very useful when you are backing up a camera into a wall and can only get the field of view you want by locating the camera outside the room.
    Post edited by mcorr on
  • Richard HaseltineRichard Haseltine Posts: 108,615
    mcorr said:
    forget what it's called, but it's a node, decal or something where you can -- for example -- make a wall in a room invisible and then with a camera outside the room look inside the room without the outside lighting affecting how the picture of the camera outside captures how you set up the lighting in the room. this can be very useful when you are backing up a camera into a wall and can only get the field of view you want by locating the camera outside the room.
    Iray Section Plane, with Clip Lights turned on in Parameters.
    yes that was exactly the way you described it the first time I read your explanation .... thank you Richard for that cool tip!!
  • RKane_1RKane_1 Posts: 3,039
    edited July 2017
    Do this with your light and camara rig to move them all at once (or just parent them to each other)
    Do it with each individual character to render one a a time.
    Do this with your set to turn it invisible to get clutter out of the way and work on the main model's pose or texture
    Post edited by RKane_1 on
  • StratDragonStratDragon Posts: 3,278
    parent your NULL to the object you attach to the NULL if the object was not centered to begin with, then un-parent the NULL and parent the object to the NULL.
    You can use the translation tool in the view window in visible view of the object and not just the translation in the parameter menu (e.g. your NULL is not 1000KM from your object, it's close or right there.) You can do this by copying the object in the scene tab then pasting to the NULL but I use Casuals parent script
    Now does anyone know a script that will let me export just one segment of a scene as an OBJ without having to "invisible" hundreds of other scene assets, including but far limited to just figures?
  • JeremyDJeremyD Posts: 265
    Yep! This is one of my favorite things to do when organizing my scene.. put everything into groups so I can hide things quickly.
    edited July 2017
    Pretty sure that you can select them all; yeh, right click and select children or one of the other options (scene tab). You can also invert selection too; I seem to remember Richard explaining something, but didn't try it out when I saw his explanation, as I was doing something else, but hopefully someone else will fill in the blanks.
    ... But select what you want to be visible, invert selection and invis them - might work.
    Post edited by nicstt on
  • kaotkblisskaotkbliss Posts: 2,914
    I just figured out that "yes! you can loop-select multiple poly's in geometry editor!"
    Selecting each poly 1 by 1 was a real PITA
  • FletcherFletcher Posts: 63
    Cntrl key to mix things up. Mix up poses, mix up materials. Cntrl e cntrl s cntrl d cntrl l... beautiful cntrl key.
