Steps for importing Marvelous Designer OBJs into DS 4.5 (Genesis)
Hi all,
Apologies for the question but I'm trying to work out how to import an obj created in Marvelous Designer into DS 4.5 (specifically clothing I've modeled in MD on an imported genesis model).
I've searched for answers and everything seems to be suggesting to use the create clothing function. However I can't find this function anywhere? When I look under assets I just get the transfer morph tools, etc but no create clothing.
Any help will be appreciated.
Thanks.
The Transfer Utility will transfer the Genesis weights and joints to the target OBJ, such as a piece of clothing from MD. You might also look at SickleYield's latest product, which includes additional templates for use with the Transfer Utility that can help get a good result.
The 'Create Clothing' was a short lived experimental feature in one of the early version of the 4.x series. It was basically must a 'short cut' way of using the above mentioned Transfer Utility.
Ahhh that explains my confusion then. I thought I shouldn't be using the Transfer Utility because everything was pointing to Create Clothing.
Thanks so much for the clarification folks. To the Transfer Utility! *cue crime fighting music*
Where can you find or what is SickleYield’s latest product?
I did a little guide for Genesis clothing creation... Maybe it could help you for some things besides the Transfer Utility.
http://www.daz3d.com/forums/discussion/14421/
Sickle Rigging and Morphing System
