Genesis and Carrara?
Which versions of Genesis will work in Carrara? Just wondering which versions of Genesis do I need to install so they can work in Carrara.
  • 3DAGE3DAGE Posts: 3,321
    Genesis 1 and 2 work in Carrara 8.5
    Carrara uses the same "smart content" database as Daz3D Studio,.
    so,.. if you have Genesis 1 and/or 2 installed in DS,. they should show up in your carrara browser (smart content).
    All previous generations of Daz3D Figures will be found in your "Content" section of the Carrara browser.
    Carrara also works with most Poser content created before version 9
    Hope it helps :)
  • DiomedeDiomede Posts: 15,468
    There is a product at that other store that will allow your Daz-bought Genesis 3 content to work in Carrara.  It is a genesis 3 character set that loads in Carrara.  Daz-bought genesis 3 content can then be converted to blended rigging in Studio and then loaded in Carrara and conformed to the G3-for-Carrara character set.  Forum regular and amazingly talented guru Misty got it done.
