genesis 2 basic female DMC
WendyLuvsCatzWendyLuvsCatz Posts: 40,326
  • TjebTjeb Posts: 507
    Have you tried every DMC file that you have?
    I don't have Genesis2, but having about 57 DMC files, I have noticed in the past that
    sometimes a DMC file that you would not expect, will give a reasonable result.
    576 x 770 - 109K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,326
    yes but she has a rigged jaw which in itself changes the way she uses facial morphs.
    I used this addition allocating visemes in iClone 3dxchange expression editor
    in Carrara I will save NLA clips which match the default ones and kit bash the rest then allocate them to the visemes in the Carrara mimic plugin.
    you do not need a Poser format cr2 to reference like you do in mimic pro, one reason I have never quite figured out mimic pro.
    I have to literally create new cr2's for any figures that do not have .dmc and mimic compatible versions and mine NEVER work!
    So many figures have viseme morphs but none of the other figure's configuration files work on them either so one needs to start from scratch and I just inspite of so many good tutorials never been able to do this in mimic pro standalone.
    G2BF looks like one of those so far, I tried a few.
  • VenerisVeneris Posts: 115
    Thank you. I already tried this and it looks good. But it shows me this message:
    "Some channels defined in the current configuration file could not be found on the figure. Lipsynching may not be as acurrate as expected."
    What's wrong? I see that the character's mouth moves correctly....
    no idea am new to this myself, did it as I needed it so sharing
    if it works should be no problem
    This will work well for "Genesis Male 2"?
    yes it does
  • I can not seem to find it anywhere, all links seem to be broken
    you no longer need it, DAZ supplied one of their own long ago, I made the file that was here before there was one
    this is an old thread
    it will be in your library under general mimic configurations
