How to zero an object extracted using geometry editor?
I needed a grocery cart prop. The Alley has a nice grocery cart, unfortunately it is not a separate prop. It is part of a single object called "boxes and cart" which included a bunch of boxes and there is aTV inside the cart. So I used geometry editor to delete the boxes and the TV that was inside the cart.
I then saved it as a support asset>figure/prop asset>grocery cart
The trouble is that the cart is not zeroed, I want it to load at 0,0,0 so that I can easily animate it. Right now it is at a weird angle and not at the center of the Daz universe.
How do I center it so the DAZ gizmo is directly over the cart?
  • Richard HaseltineRichard Haseltine Posts: 108,453
    Position it at the origin, export as OBJ, reimport using the same preset, reapply material settings, save as asset.
  • FrankTheTankFrankTheTank Posts: 1,510
    edited June 2017
    Richard, thanks for your help, that worked! (finally)
    Post edited by FrankTheTank on
