GenX - Problems - How To Uninstall All of It?
FauvistFauvist Posts: 2,290
How do I uninstall GenX from DAZ STudio?  I want to get rid of it and GenX files that currently show up in the Parameters Pane etc.  Then I can reinstall it.
Thanks!
  • nonesuch00nonesuch00 Posts: 18,856
    1) If you installed via DIM, use DIM to uninstall.
    2) If you installed within DAZ Studio 'Content Manager' right click with mouse & install.
    3) If you downloaded & installed manually most of those installers give the option of creating an uninstaller. Use that uninstaller.
    4) If for some reason you installed manually but don't have uninstalled I think but am not 100% sure that installing the products a second time via DIM will install all the product files in the same location as a manual install and then allow you to uninstall easily via DIM.
    5) If you have installed via both Content Manager and DIM and/or manual install means you have 2 installs in different places on your storage and you must uninstall both via 1 & 2, 2 & 3, or possibly 2 & 4.
  • almahiedraalmahiedra Posts: 1,370
    edited June 2017
    I see two places with GenX content (GenX2 and 64bits win7 in my case)
    C:\Program Files\DAZ 3D\DAZStudio4\plugins\d3dGenX2.dll
    C:\Users\Your User\AppData\Roaming\DAZ 3D\Studio4\GenX2
    Use or abuse of this information under your own risk. Try first with nonesuch00 alternatives.
    Post edited by almahiedra on
