GenX - Problems - How To Uninstall All of It?
Fauvist
in The Commons
How do I uninstall GenX from DAZ STudio? I want to get rid of it and GenX files that currently show up in the Parameters Pane etc. Then I can reinstall it.
Thanks!
1) If you installed via DIM, use DIM to uninstall.
2) If you installed within DAZ Studio 'Content Manager' right click with mouse & install.
3) If you downloaded & installed manually most of those installers give the option of creating an uninstaller. Use that uninstaller.
4) If for some reason you installed manually but don't have uninstalled I think but am not 100% sure that installing the products a second time via DIM will install all the product files in the same location as a manual install and then allow you to uninstall easily via DIM.
5) If you have installed via both Content Manager and DIM and/or manual install means you have 2 installs in different places on your storage and you must uninstall both via 1 & 2, 2 & 3, or possibly 2 & 4.
I see two places with GenX content (GenX2 and 64bits win7 in my case)
C:\Program Files\DAZ 3D\DAZStudio4\plugins\d3dGenX2.dll
C:\Users\Your User\AppData\Roaming\DAZ 3D\Studio4\GenX2
Use or abuse of this information under your own risk. Try first with nonesuch00 alternatives.
