Genesis8 tear problem
I'm having some problems with the G8 eyelashes. When I import the morph the 'tear' part of the lash grows big like in the picture. I am very careful with sculpting only the lash part, (I mask out the tear in zbrush) and it works fine until I import the morph via morph loader.
This happens in old and updated version of DS (Windows10 64X). Any help would be greatly appreciated as I'm trying to figure this out for the last 3 days.
    edited June 2017
    Use "reverse defomation" option. because Eye lash already morphed by Hidden parameter "Eye lashed expand" as 100%
    it is locked, and limited, then  can not change value. but if you use morph loader without reverse defomation, morph make delata from zero.
    I happend to be found same thing when I try to import tear morph (not eye lash)
    1031 x 679 - 123K
    1000 x 697 - 141K
    Post edited by kitakoredaz on
  • MoussoMousso Posts: 245
    edited June 2017
    Thank you, I will try that.
    edit: Yess it works! laugh
    Post edited by Mousso on
    If you did not ask it,, I might  ask same thing  , I usually use reverse defomation,  then have not found such problem ^^;
     the hidden expand eye lash morph  is not be shown as currently used. it is cheat morph I think,,  (I could not find it before)
    1160 x 751 - 163K
