Re Basics for Genesis 8
On the G8 page (I think!) it says that the basics are free withthe new Daz download, but I've only just updated to the new Daz and there's no G8 anywhere. So am I right that the basics should be there? - or have I misunderstood something?
Also a petty question: why leap from Genesis 3 to 8? What happened to 4-7?
  • frank0314frank0314 Posts: 15,109
    How are you installing your products? DIM or manual? The change was made to make it easier for the user to know which Genesis goes with which Vicky. So any character product that comes out with the number 8 in it you know it goes to Genesis 8
  • Prince WaoPrince Wao Posts: 373
    edited June 2017
    I use the DIM. I updated my Daz on the 14th, but there are no G8 Starter Essentials anywhere.
    Gnesis "8" now makes sense! Thank you.
    Post edited by Prince Wao on
  • FistyFisty Posts: 3,416
    They are a seperate download from Studio, type "starter" in the search field in DIM and you should see them.
  • SimonJMSimonJM Posts: 6,101
    They are free, a new downlaod 'set' along with the essentials for teh previous Genesis versions - check DIM (if you use that)
    Thanks everyone! I have it sorted now. smiley
  • BobvanBobvan Posts: 2,653
    edited June 2017
    Question. just played with auto fit good to know lots of genesis stuff work as for skin I tried applying a G2F didnt work too well how does one load it / adjust it?
    Post edited by Bobvan on
  • Charlie JudgeCharlie Judge Posts: 13,629
    I asked pretty much the same question over in the "Backwards Compatibility" thread It seemed like G3F skins would work on G8F but G2F and earlier skins  wouldn't work. Any suggestion would be welcome.
  • 3anson3anson Posts: 314
    Currently Genesis8Female and Victoria8 will only take G8F/V8 and Genesis3Female skin textures.
    To be able to use Genesis2Female( and earlier ) skin textures you need to convert them to Genesis3Female first.( there are several ways to do this, it can be done in Blender, or probably the
    easiest and quickest would be to purchase the texture converter app by Blacksmith3D, with any extra figure plug-ins that you require.smileywink
    I think it's generally agreed that the must effective and seemless solution is the BlackSmith Texture Transformer program & set of plugins at the Rendo site. There is also a tutorial that SickleYield wrote that is not as seemless but might be adaptable for your needs.
     http://sickleyield.deviantart.com/journal/TUTORIAL-Character-Skins-G2-to-G3-Via-Skinsuit-670659335?showbanner=false
    Ha ok im not imagining things a tip DX30's High boots 3 for G2F work well just need to hide the feet..
