G3 skin on G8 - white lines at arms and legs
I have a problem with the skin of Cassiopeia for G3. When I apply her skin to G8 (unmorphed), there are white lines at the border Arm texture -> Torso texture and the same for the legs. Head/Face seems to be okay.
I don't have that with other skins I've tried, so I guess there's something with the Cassiopeia skin - but it looks okay on G3, which it was created for.
Not sure if this can be considered a bug, is there anything I can do to fix this?
Thank you :)
Post edited by mork on
Does she use custom UVs or the default Genesis 3 Female ones? That's really the only thing I can think of that might cause that.
Oh, she indeed uses Victoria 7 UV. :( Did not see this, thank you for the hint.
At least this won't bite us in the backside at the next generation change if DAZ keeps the same basic UV layout intact. V8 uses the base female UVs.
