What's wrong with my gal?
PedroCPedroC Posts: 200
In Victoria 8's description page, the height is: 5 '10 "(179.3 cm) Same as Victoria 7. But Victoria 8 in my case, appears with a higher height.I uninstall and reinstall with DIM and with Dazz Connect but the result is the same.
Scaling, parameters and morphs appear to be correct. What may be happening?
Post edited by PedroC on
  • cm152335cm152335 Posts: 421
    edited June 2017
    i test,,
    i loag basic "Genesis3" and "Genesis 8"
    they are 100% identical,,
    some change only when you apply character,,
    681 x 849 - 85K
    Post edited by cm152335 on
  • PedroCPedroC Posts: 200
    cm152335 said:
    i test,,
    The problem is not with the base G8F is with Victoria 8, the height dosen't match with 5' 10" (179.3 cm) indicated in the Victoria 8 page, (at least in my case).
    PedroC said:
    cm152335 said:
    i test,,
    in 'shaping' use Legs length -20% on V8 and V7/V8 become  same,,
  • Richard HaseltineRichard Haseltine Posts: 108,531
    Which version of Daz Studio?
  • fastbike1fastbike1 Posts: 4,079
    edited June 2017
    4.9.4.117
    V7, G8, V8
    1048 x 758 - 93K
    Post edited by Chohole on
    latest
    4.9.4.117 (64 bits)
    640 x 480 - 471K
    edited June 2017
    fastbike1 said:
    4.9.4.117
    V7, G8, V8
    Victoria V8 is about 183 cm tall.
    Edit: V8 in " T " pose is 184.9 cm. tall a script to read dimensions tells.
    We have asked about this.
