What's wrong with my gal?
PedroCPedroC Posts: 200
In Victoria 8's description page, the height is: 5 '10 "(179.3 cm) Same as Victoria 7. But Victoria 8 in my case, appears with a higher height.I uninstall and reinstall with DIM and with Dazz Connect but the result is the same.
Scaling, parameters and morphs appear to be correct. What may be happening?
1285 x 927 - 338K
Post edited by PedroC on
  • cm152335cm152335 Posts: 421
    edited June 2017
    i test,,
    i loag basic "Genesis3" and "Genesis 8"
    they are 100% identical,,
    some change only when you apply character,,
    681 x 849 - 85K
    Post edited by cm152335 on
  • PedroCPedroC Posts: 200
    cm152335 said:
    i test,,
    The problem is not with the base G8F is with Victoria 8, the height dosen't match with 5' 10" (179.3 cm) indicated in the Victoria 8 page, (at least in my case).
    PedroC said:
    cm152335 said:
    i test,,
    in 'shaping' use Legs length -20% on V8 and V7/V8 become  same,,
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Which version of Daz Studio?
  • fastbike1fastbike1 Posts: 4,085
    edited June 2017
    4.9.4.117
    V7, G8, V8
    1048 x 758 - 93K
    Post edited by Chohole on
    latest
    4.9.4.117 (64 bits)
    640 x 480 - 471K
    edited June 2017
    fastbike1 said:
    4.9.4.117
    V7, G8, V8
    Victoria V8 is about 183 cm tall.
    Edit: V8 in " T " pose is 184.9 cm. tall a script to read dimensions tells.
    We have asked about this.
