Merging UV sets?
Scavenger
i'm working with a model that has multiple UV sets.
I'm working with a model that has multiple UV sets.
As in one the service uses default another uses a set called UV too.
Is there a way to save the model so the UV sets that are used merge into a single one?
Post edited by Scavenger on
Are they diffrent or two sets with the same layout?
there are differences....
What I'm wondering is is there some way to make a FrakenUVmap with the parts from each.
Would exporting to obj, then grabbing the uv from that obj do it?
Sure, you could make a new UV (as long as you have the rights to both, assuming this is for distribution).
And I would make the new UV.....by the obj method I suggested?
The ansewer is yes.. exporting to an object will create a single frankenUVmap!
