Merging UV sets?
ScavengerScavenger Posts: 2,677
edited June 2017 in The Commons
i'm working with a model that has multiple UV sets.
 I'm working with a model that has multiple UV sets.
As in one the service uses default another uses a set called UV too.
 Is there a way to save the model so the UV sets that are used merge into a single one?
Post edited by Scavenger on
  • Richard HaseltineRichard Haseltine Posts: 111,779
    Are they diffrent or two sets with the same layout?
  • ScavengerScavenger Posts: 2,677
    edited June 2017
    there are differences....
    What I'm wondering is is there some way to make a FrakenUVmap with the parts from each.
    Would exporting to obj, then grabbing the uv from that obj do it?
    Sure, you could make a new UV (as long as you have the rights to both, assuming this is for distribution).
    And I would make the new UV.....by the obj method I suggested?
    The ansewer is yes.. exporting to an object will create a single frankenUVmap!
