(Commercial) Great Lashes for Genesis 8 available now!!!
Virtual_WorldVirtual_World Posts: 1,101
Enhance the beauty of any Genesis 8 Female character with these great lashes https://www.daz3d.com/great-lashes-for-genesis-8-female-s
This package contains morphs, colors and styles that can be applied to the upper and lower lashes individually.
YouTube videos showing how to use the product:
How to use custom morphs:  http://youtu.be/CBeW4ekuCnY
How to apply colors and styles to any character using Genesis 8 Base Eyelashes (upper/lower lashes at the same time): https://youtu.be/MtbNMvY3yfo
How to apply colors and styles to any character using Genesis 8 Eyelashes with Custom Material Zones included with this product (upper and/or lower lashes independently of each other): https://youtu.be/ypc4qS7bVbA
Post edited by Virtual_World on
«1
  • Virtual_WorldVirtual_World Posts: 1,101
    edited June 2017
    Custom morphs included.  You can control how long or pointed are the lashes.
    1000 x 1300 - 609K
    Post edited by Chohole on
    edited June 2017
    Some renders showing how they look on Genesis 8
    1000 x 1300 - 1M
    edited June 2017
    1000 x 1300 - 999K
    edited June 2017
    Now it is possible to apply one color to the upper lashes and a different color to the lower lashes.  In this render she has blue upper lashes and purple lower lashes.
    1000 x 1300 - 2M
    edited June 2017
    This is Victoria 8 with one of the Great Lashes.  Skin is from Adele for Genesis 3.
    500 x 650 - 339K
  • ArtiniArtini Posts: 10,302
    Looks great. It was an instant buy for me.
  • vwranglervwrangler Posts: 4,971
    Looks like a very nice and useful product!
    ... Although every time I see the name, all I can think of is an old Maybelline commercial!
    Thanks so much Artini!!!!
    LOL.... Thankswink!!!!
  • alexhcowleyalexhcowley Posts: 2,402
    This is a great render. I really like the subtle facial expression. It's also an excellent advertisment for your product.
    Cheers,
    Alex.
  • fastbike1fastbike1 Posts: 4,078
    edited June 2017
    I'm having some trouble. I hid the stock eyelashes and followed the Apply 1 and Apply 2 after 1 in the custom folder. I found the morphs (see screen shot) and applied some changes.
    Then applied colors and rendered, but the render is goofy. What am I missing?
    535 x 579 - 59K
    500 x 750 - 509K
    Post edited by fastbike1 on
    edited June 2017
    Double post
    edited June 2017
    Cheers,
    Alex.
    Thanks so much for your comment Alex!!!! Glad you liked it!
    edited June 2017
    Thanks for your support acquiring my product fastbike1.  Below you will find an explanation about how to use the product.
    Genesis 8 Default Lashes come with two material zones: Eyelashes and EyeMoisture.
    The material zone identified as Eyelashes controls the materials for both the upper and the lower lashes.
    My product comes with material presets that can be applied to both eyelashes at the same time, as any other product that comes with material preset for the eyelashes.  The folder that contains those material presets is identified as For Default Lashes with One Surface.
    To use the product this way the steps are:
    Load Genesis 8
    Select the Eyelashes
    Select the Iray or 3Delight folder
    Select the forlder identified as For Default Lashes with One Surface
    Apply the Default Material preset
    Apply your preferred color
    Apply your preferred style
    (you can apply color and styles in any order)
    450 x 325 - 70K
    736 x 182 - 62K
    758 x 758 - 101K
    edited June 2017
    My product also comes with the option to apply styles and colors for the upper or the lower lashes individually.   For that reason I had to create two additional material zones.  One to control the upper lashes and the other one to control the lower lashes.
    The folder that contains individual presets is identified as For Custom Lashes with Two Material Zones
    To use the product this way, the steps are:
    Load Genesis 8
    Delete or Hide the Default Eyelashes
    Select the folder for your preferred render engine: 3Delight or Iray
    Select the folder identified as For Custom Lashes with Two Material Zones
    Load the Custom Eyelashes with the two addtional material zones.
    Apply the default material preset
    Select the folder identified as Great lashes Lower
    Apply your preferred color for the lower eyelashes
    Apply your preferred style for the lower eyelashes
    (colors and style can be applied in any order)
    Go back and select the folder identified as Great Lashes Upper
    Apply your preferred color for the upper eyelashes
    Apply your preferred style for the upper eyelashes
    979 x 100 - 65K
    487 x 418 - 86K
    511 x 449 - 44K
    470 x 792 - 64K
    504 x 811 - 71K
    edited June 2017
    Go to the Parameters or the Shaping tabs and change the values of the included morphs, to increase or reduce the size of the lashes, etc...
    1211 x 463 - 75K
    For additional information, please view the Readme file http://docs.daz3d.com/doku.php/public/read_me/index/43975/start
    Hope that the explanation above can help you.  smiley
    Cheers,
    Alex.
    You are most welcome.  I had a play around with  Victoria 8 yesterday. I'm not impressed by the eyelashes as supplied so your product has gone into next week's shopping list.
    Cheers,
    Alex.
  • Rod Wise DriggoRod Wise Driggo Posts: 2,309
    Great product but I'm facing problems applying. The colors are applied either one or two-tone but the lashes are way to short and seem not to apply the styles altough I used the "Apply First"-thingy. Any idea?
    Cheers,
    Alex.
    Cheers,
    Alex.
    Thank You!!!
    Thanks so much for the detailed answer. I think my big problem was that I didn't see the files for the lash morphs in the folders, but only the color changes. I was then using the sliders without applying a morph. I uninstalled/reinstalled and the shaping  icons are where they should be. I either had some kind of DIM install issue or i just didn't scroll. I was in a bit of a hurry, so probably user error. Anyway thanks so much for the response, that really helps.
    edited June 2017
    Sorry for the inconvenience.  Here there is a video to show you how to use the Lashes morphs.  Later, I will post a video to show how to change colors and styles ( I am working on it right now).
    https://youtu.be/CBeW4ekuCnY
    edited June 2017
    This is a video showing how to apply colors and styles to Genesis 8, Victoria 8 or any other characters that uses the Genesis 8 Default Eyelashes
    This is a video showing how to apply colors and styles individually to the upper and/or lower eyelashes to Genesis 8, Victoria 8 or any other character using the Eyelashes with Custom Material Zones included in this product
    You are very welcome!!!!
  • GreybroGreybro Posts: 2,599
    I just wanted to chime in that this is a great product!
    2000 x 1125 - 3M
    LOL... Looks fantastic with the big eyelashes... LOL   Thanks so much for your post, I appreciate it very very much! heart
  • DaikatanaDaikatana Posts: 830
    Picked this one up as soon as I saw it in the store and so far it's working wonderfully.
    edited June 2017
    Fantastic!!! Thanks for your support acquiring my product and for commenting!!!! smiley
    edited June 2017
    To remind you that there are only a few days left to end the introductory discount of my product Great Lashes for Genesis 8
    500 x 650 - 634K
  • IceDragonArtIceDragonArt Posts: 12,744
    These are gorgeous!
