Issue with HDR Environment. Looks like it's in a Sphere
DDCreateDDCreate Posts: 1,416
Does anyone know what is causing this effect? I opened a NEW image, loaded the barracks and then applied an HDR light and background. Why is it behaving this way? Does anyone know?
  • FishtalesFishtales Posts: 6,224
    It is set to Finite Sphere and a small radius which is set to just cover the building by the look of it. Increase the radius of the Finite Sphere or change to Infinite Sphere.
  • DDCreateDDCreate Posts: 1,416
    Thanks FishTales! One more quick question...what if I don't want the HDR background anymore?
    edited June 2017
    Remove the image from the Environment Map or set the Environment Mode to Sun & Sky Only.
    Post edited by Fishtales on
  • OstadanOstadan Posts: 1,130
    Or, if you mean you want its lighting but don't want to see the image, turn off the 'Show Dome' parameter in the Render->Environment tab.
  • JamesJABJamesJAB Posts: 1,766
    Your issue could also be because of your camera settings.
    Go into your camera and set the "Focal length" to something higher like 150 or 200, then move the camera to a location that gives you the same view of your building.
    Give that a try and see how it looks.
