Diffuse Overlay Color looses it's map channel
ScavengerScavenger Posts: 2,677
My diffuse overlay color has lost it's map channel. (pic 1)
It had it.  I copy pasted surface settings from another surface to it (which has it ...pic 2)..it vanishes.
I change the surface to something else, it comes back...I go back to the surface I want (pic 1)...it goes away again.
Anyone have thoughts on this?
    Did the other surface you copy from have the UberIray shader?
  • ScavengerScavenger Posts: 2,677
    Yes. both have iray uber.
    should be no difference, and in all variations, but this one, they're the same.
  • EtriganEtrigan Posts: 603
    I'm not at my D|S computer to check this out; but, what do you get when you click the "down" arrow beside the Diffuse Overlay Weight? I'm thinking there's an "add map" or some-such.
    Well, changing the surfae to daz default (3DL), then hitting it with Uber iray, then pasting the desired settings and everything was fine.
    shurg.sigh
