General Freebie Requests
Adding to Cart…
Just so other folks don't have to hunt:
http://en.wikipedia.org/wiki/File:Dickens_Gurney_head.jpg
The closest I've ever seen to that is Mitch Hair, and that isn't very close...
Eustace,
I would try using the Garibaldi hair plug in. Here is the link to the DAZ thread
http://www.daz3d.com/forums/discussion/9943/
I am looking for clothing and accessories to use in viking/norse themed renders.
I’ve been searching for some time now, but didn’t find anything I really liked (Except a wonderful early medieval tunic freebie…dynamic at that.. but only for poser *bangshead*). The stuff should be halfway historically correct *g*, I found some helmets and swords
It would be great if anyone round here maybe had a link or two…...
The stuff in different stores is eiter too expensive for me right now or too old.
M4 or maybe genesis, but i’d prefer M4 .
Eustace,
that plugin looks awesome!!
seems to work just as fine as LAMH (http://www.daz3d.com/look-at-my-hair)
Viking ... difficult ...
Free
Houses (page 1 and 4): http://www.heltkonge.no/baldi/3dmodels3.htm
Ship http://www.planit3d.com/source/meshes_files/viking.html
Viking in Rero freestuff http://www.renderosity.com/mod/freestuff/search.php?section_id=-1&query=viking
Sharecg http://www.sharecg.com/b/11/Poser/?keywords=viking
http://www.sharecg.com/b/5/3D-Models/?keywords=viking
Norse sword http://www.renderosity.com/mod/freestuff/details.php?item_id=63787
Not free ...
For ApolloMaximus: http://www.adh3d.com/viking.html
Weapons: http://www.contentparadise.com/productDetails.aspx?id=1185
Helmet http://www.contentparadise.com/productDetails.aspx?id=8826
Rings http://www.contentparadise.com/productDetails.aspx?id=8829
Looking for poses for Mill dragon LE, using DS 4.0.
Could only find poses for DS 4.5.
Can anyone help?
Kirisute has some Mildragon poses:
http://kirisute.vitusware.net/VitusSDS/
Rabe,
One thing that might help you is the following process to use an unrigged clothing article on any of the Gen 4 figures.
1. Load up the figure and the clothing item into the scene.
2. Go to the Scene tab and select the figure. On the Tab bar you will see an icon that has an arrow and four lines on it. Click on this and go to Edit -> Convert figure to Weight Mapping ...
3. Select the clothing object.
4. Click on the Tab icon again and select Assets -> Transfer Utility
5. A box will open up and your source will be the Gen 4 figure and the Target will be the clothing object. Select Accept.
You now have a simple rig on your clothing that will follow the figure. This will not work on say a cloak that is a plane and requires bending around the body of the figure but for a shirt or pants or a tunic this process will work. For Genesis you do not need to do the weight mapping because it is already weight mapped. I have not tried this on say Antonia or BVH's Angela but I bet it would work with them as well. Remember that morphs may or may not be supported in the clothing. Happy hunting!
I've just tried downloading several items from this site, but when I try to extract the compressed files I was told the folders were all empty.
Yeah, I got that while trying to get the khopesh. But, by luck I'd another link saved, and the download should work on this version of the site: http://kirisute.vitusware.com/VitusSDS/
Well I've psoed the dragon myself now, but the other stuff looks interesting, so I'll have another go.
Cheers!
yummy... that one looks cool...
hmmmm... guess I'll have to save some money ^^
Thank you!
Found this one!
http://archive3d.net/?a=download&id=a794ca6a electric violin
The .3ds files can be imported into Bryce, exported as .obj ... imported into Hexagon and resized/repositioned and exported. Then imported into D/S and turned into a prop!
Psst, Hexagon can import .3ds files :) You can skip Bryce! :)
shock, horror, why what you want to skip Bryce. :bug: (joking)
Guess it happened that once too often Hexagon was supposed to import certain files and couldn't ... therefore I don't tend to think of it first for opening anything but .obj and sometimes it's own files.
IF ONLY HEXAGON DIDN'T CRASH SO MUCH... AND DIDN'T HAVE THAT MANY BUGS....
well.... we can't complain about something that is given to us for free...
Well, some people paid good money for years back ... but it is an "old" program with old coding apparently that I gathered from reading around is not easy to update. So we'll be happy that it works at all. Certainly works well for making morphs.
Oh and I discovered that the smoothing tool crashes it with a low poly mesh, but if one smooths it to level 2, then it works fine. Mine not to reason why. nope.
is there a 3d model Cintia Dicker ?
You could always try to recreate her face via the FaceGen function (which comes free with the exporter, albeit with a 3D "watermark" on the forehead of the morph). The morph would be for Genesis though.
http://www.facegen.com/
Check out the "Downloads" section for more info.
I was wondering if they are any freebies (preferably for M4/V4/A4/H4 or Genesis) of huipil dresses: http://www.ihrivieramaya.com/blog/huipil1246.jpg
I am also on the lookout for Central Asian clothing such as this: http://www.thelovelyplanet.net/wp-content/uploads/2012/08/traditional_kyrgyz_dance_Go.Live_.Serve_..jpg
Thanks in advance!
Hello!
I was wondering if someone could help me with a little morph: I need a chest-spandex type morph for V4 Elite Utopian (with the breast size of -60%). I know there is a chest spandex morph available, but that doesn't give good results on the utopian morph. :roll:
I need it for a personal project, where I want to make a second-skin outfit to apply as clothing, and the second-skin was the only technique that allowed me to texture it the way I wanted. :red:
I'd really appreciate the help, and I can send the morph pose file to be easier to work on it.
Hello, again…
I'm wondering if anybody happens to have all the files from this page:
http://web.archive.org/web/20071023065820/http://xposer.org/hosting/dlpage.html
I found a couple of threads on the Forum archive relating to these files, so I know at least one person has them…
Even if someon has them they cannot let you have a copy, that would be against the creator's EULA
dddx, I am assuming that you are wishing for alternate download locations:
These look like Shukky's stuff. Go here:
http://www.sharecg.com/pf/full_uploads.php?pf_user_name=sasuke256
Already have those, I was referring to a bunch that aren't hosted anywhere…
And the creator seems to have disappeared…
Sad, this seems to be the case with many abandoned things (Poser or otherwise)…
dddx,
So sorry to have troubled you with information you already had. It may have been more helpful if you identified specifically on the page what you were looking for. What I see in the pictures below the download buttons are things on Sasuke256's gallery. They have been repackaged but maybe you did want the older versions. So accept my apologies for having troubled you with bad information.
@Dollygirl
I was referring to these items:
http://web.archive.org/web/20071107042116im_/http://xposer.org/hosting/A3_Chunli.jpg
http://web.archive.org/web/20071107042111im_/http://xposer.org/hosting/CB_PrincessClown.jpg
http://web.archive.org/web/20071107041827im_/http://xposer.org/hosting/ssost_th.jpg
http://web.archive.org/web/20071107041816im_/http://xposer.org/hosting/216352465_21.jpg
http://web.archive.org/web/20071107041821im_/http://xposer.org/hosting/v3_ps.jpg
http://web.archive.org/web/20071107041826im_/http://xposer.org/hosting/plugs_th.jpg
http://web.archive.org/web/20071107041830im_/http://xposer.org/hosting/SAC_th.jpg
Some of the other items (GodOfDead, BoneHorse) are available on ShareCG, however…
Many of Shukky's items are still available...including some from that page.
There are some here
Does it absolutely need to be Shukky's versions of the outfits? If you're willing to accept clothing for V4 instead of V3 and A3, nearly half of these have alternatives:
http://freelancecomics.blogspot.ca/2011/04/descargas-downloads.html
(And, yeah, I want a copy of the one illustrated by http://web.archive.org/web/20071107041816im_/http://xposer.org/hosting/216352465_21.jpg, too - but only if I can get it legally Maybe somebody could make a more modern version of it... especially if we give them better reference images to work with.)
@robkelk
While those are great alternatives, I already have all those… :/
I tend to prefer Aiko 3 over Aiko 4… Renders take less time, etc…
Incidentally, are there any other links for the following?
http://www.3digitalcrafts.net/studiomaya/1download/character/yuna.zip
http://www.3digitalcrafts.net/studiomaya/1download/mayahair/SpiralTwinTail_BJD.zip
