Ever seen this? The camera obstruct its own view!
iSeeThisiSeeThis Posts: 560
Well, I feel like a newbie again. And I may be stupid or ignorant not to understand this. I've rendered 47 frames without any problems. But at frame 48 it rendered a blue (blank) one. I've tried to change some parameters but failed. And then I notice that it turns blue from the frame I see the camera outline (as attached). How can this happen? I used perspective camera to see it and found nothing wrong. Thanks in advance!
Post edited by iSeeThis on
  • Richard HaseltineRichard Haseltine Posts: 112,089
    Are you sure it's the camera and not a light? In Iray, with Render Emitter on, if a light has a shape that shape will obstruct the view when seen from behind.
  • iSeeThisiSeeThis Posts: 560
    Thank you Richard! Quite sure about it cuz I have no light in the scene. Just use sun only.
  • RayztoneRayztone Posts: 17
    It kind of looks like it's rendering the perspective camera. Maybe just one of those weird gliches that sometimes happen.
