Can terradome 3 be converted to 3Delight?
Is it possible to convert the terradome 3 textures to 3delight?
  • Oso3DOso3D Posts: 15,087
    Sorta. The problem is that terradome3's shader interleaves two textures, which... hmm. You MIGHT be able to use one of Stonemason's textures, like from winter terrain. Maybe.
    Otherwise, you can apply the textures from one or the other of the textures.
    Another option is to dig in my freebies thread (  https://www.daz3d.com/forums/discussion/141136/will-s-freebies ). There's some shader in there that sets a Normal-based mask in 3DL; you could add a geoshell to the terrain and have a second 'on tops of stuff' effect. But at that point you are doubling geometry.
    What I've generally done is simply use one of the rock or ground shaders and call it a day. Sometimes I've made two terrains, one compressed slightly, and put grass shader or something on it.
