Building New Computer for iRay
Ray123Ray123 Posts: 3
Hello Everyone,
I am going to be building my first computer! It will be specifically designed for iRay rendering and other graphic design projects. I have selected the parts I want to use for the new computer, but before I go out and buy these parts I would like to make sure that it will actually work optimally with iRay. Here are the important parts:
  • CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor
  • Memory: 32 GB RAM
  • GPU: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G Video Card
The whole list of computer parts is attached as an image if you would like to see them.
With this hardware, will I be able to have blazingly fast iRay render times? Are there certain parts that I should replace? Any feedback on the computer's parts is greatly appreciated.
Post edited by Ray123 on
  • JamesJABJamesJAB Posts: 1,766
    So, two things to consider.
    Get an aftermarket heatsink/fan for your CPU (one with a 120mm fan) for quieter and cooler opperation
    Upgrade to Windows 10 Pro so you have more control over when windows updates are applied and when the computer restarts for pending updates. (last thing you want is windows to install updates and reboot in the middle of a giant overnight render)
  • fastbike1fastbike1 Posts: 4,085
    edited May 2017
    If you're really serious about rendering, now is the time to go watercooling for both the CPU and the 1080Ti
    Post edited by fastbike1 on
  • Ray123Ray123 Posts: 3
    According to the AMD - Ryzen 7 1700 3.0GHz 8-Core Processor product page it says the CPU comes with the following:
    Cooling Device: Heatsink and fan included
    The cooler is called the AMD Wraith Spire Cooler, do you think it will be adequate? So far the questions answered on the newegg site seem to indicate that it works pretty well.
    The sound of watercooling sounds terrifying to me, I have never tried watercooling before. I'm afraid I'll screw up and fill my PC with water, haha laugh
    Adequate?  Yes.
    I always recommend Heatsink/Fan combos the use at least 120mm fans because they move a lot of air at low RPMs.  Makes for a much quieter system while under load.  Here is a good example of the style that I use on my custom builds.
  • FossilFossil Posts: 166
    Pick up the June copy of Maximum PC ( http://www.pcgamer.com/hardware/ ).  They've got a review of Ryzen motherboards this month.
    The online version is not complete as they've recently merged with PC Gamer.  Grab the paper copy.
