Is there a Blender node in Shader Mixer? Answer: the Mix brick
2»
  • 3dcheapskate3dcheapskate Posts: 2,732
    edited February 2013
    Hmmm... I'm sure it must be something really simple since your network looks fine - well, at least you're not making any of the stupid mistakes I usually do, like using an Image Alpha output for a JPG! :roll:
    The only thing I can think of now is the mask image itself - tc11SkirtGreenVelvet.jpg. You're not using shades of grey in it are you? There'll be some grey patches around the boundaries between the velvet/patterned ares due to the JPG compression for sure, but that shouldn't cause what you're seeing. If your using greys that'll be the problem. If not, and you're using just black (0,0,0) and white (255,255,255) then I'm at a loss...
    Post edited by 3dcheapskate on
  • KeryaKerya Posts: 10,943
    No - it is absolutely black and white ... apart from jpg compression at the border. The border is black, the rest is white.
    P.S. if you look at the first page: I did use the Image alpha output first. LOL
    Pendraia said:
    Kerya said:
    Thank you Bejaymac!
    I was tired when I tried that.
    (Note to myself: don't dare the shadermixer when you are tired!)
    I want two different Bumps - I just imported the shader from the existing texture and thought I can split from there.
    A noise map at the bottom of the skirt to get a velvet effect hemline and "normal" cloth bump map for the rest.
    OK, and specular will get two different settings too (if I succeed) a velvet node for the hemline and normal for the rest.
    Pendraia: you lost me. Looks great, but I really can't visualize what you did to get those effects it. LOL
    Sorry I lost you...I'll try and post the network this weekend. Won't get time before that as I started back at work today.
    I just realised I never got back to this thread. So sorry about that I stopped getting notifications only found it again when someone posted a link. I'm on holidays at the moment so I'll try and get around to posting the networks during the next week.
    No problem - I got distracted too. After I solved my problem of the Skirt and Top looking different - don't ask me how, I forgot - I put the whole thing in a folder and was happy. Maybe I should take it up again, I just have to make some promo pictures. LOL
    But as I got PP2014 now and want to install it and play with it ... too much fun, not enough time.
    Lol I wish that was my problem. Mine is more too much work...
    That too - but work doesn't sound as nice. ;)
    lol...you're right there!
