Skin Iray shader for Belle 6
Hello, I used anagenessis 2 In Belle 6. The result is good in general, but sometimes, depending of the light I can see intense red-pink tone in her legs that no correspondence with the rest of the tone in the skin. Also have the same problem in other skin of genesis 2. That overtoned is annoying. And it looks like the texture of the legs are overcolored. With the Domina skin occurs the same. Anagenessis is a very good shader, but this problem... The others shaders no have that problem, but its looks detailless.
  • Tim NTim N Posts: 193
    I see a mild redness in the legs when I use the Belle 6 skin, but not to the same degree. Perhaps your HDRI map is contributing the colour cast? If not, have you ensured that all your lights have a colour temperature of 6500 K?
    As for shaders, I've always been very happy with "Iray Smart Converter and Advanced Skin Managers for Genesis 2" by V3Digitimes.
  • IsazformsIsazforms Posts: 210
    Thanks for your answer. I just wanted to confirm that I really recommend the shader you mentioned.
    Some administrator have deleted the sample image.indecisionsurprise
    No, it's still there.
