hair poking though hat help
Fabe
I need some help figuring out how to prevent hair from poking though hats. I've found some products that prevent this but they're for genesis 2 or 3 and I'm I still working with genesis 1.
I don't know of anything in the Daz store, but the Sickle Super Hat and Hair Fixer over at Renderosity should meet your needs.
Couple other options:
got links to tutorials for those sorts of things?
. even after a;ll these year of playing arounf with daz there is still lots I don;t know or understand
Sure.
Ok now I know I'm really clueless about daz,what is the hmabuger menu icon?
Haha, it's my name for this icon (see attached).
Better known as a list menu...
What I do is go into 'Geometry Editor' mode and then 'Select by Polygon' with 'Shift' key pressed (adds to those polygons already selected) and then right click and 'hide selected polygons'
A Push Modifier, with a negative value, and adjusted by a weight map (Create>New Push Modifier Weight Node) is another option.
Thanks for all the help everyone. I've tried using the gemerty edtior but it seems to remove parts of the hat even if I add the hat after trying to hide parts of the hair. Its really anoying since all the promo pics for hats don't have any poke though. I trhink I'll just get that Hat and Hair Fixer from Renderosity. Hoefullly that will work as well as it claims.
Sickleyield has a Hat and Hair Helper for G1 over at Rendo.
mm,,,If geometry editor hide hair, it means you select hair and hair poligons, not hat. or the hat is offered with hair as one mesh? Because geometry editor can only hide poligons with your selection. may better to know clear geometry editor usage, for future purpose.
https://www.daz3d.com/forums/discussion/42088/tutorial-adding-surfaces-in-ds-with-the-geometry-editor-tool
I do not know, when fixmypcmike offered this tuotriall, but most of step should be correct about current daz studio too. (current version geoemtry editor may have some more option)
It help a lot to know Select poligons as you like with geometry editor ,with each select options.
then you may need not to keep zero pose, you may bettrer try same step (hide selected hair poligons) with posing figure, posing hair,, or you will need to adjust hiding parts with current hair posing again. (it frequently happen,,)
Well Stickleyeild's hat fixed went on sale so I just pucked that up. I think that might be easier for me to use then geometry edting . how ever Ido have one more quick question. How do I conform things to each other. I need to conform the hair I want to use to the hair fixer then the hair fixer to genesis.
