UHT2: Can't Use Fantasy Colors With The Script From The Original
Hey, as said above I'm having issues figuring out how to get the new shaders from the UHT2: Fantasy pack into the Color Mixer script from the base UHT2. I want to ombre a fantasy color into the hair I've chosen but I can't do it. I've tried googling, watching the instructional videos, and playing around and can't figure it out. How do I load those colors into the script?
  • dave321dave321 Posts: 23
    Well, in case anyone sees this looking for a solution, my bandaid fix was to copy all the files into the folder of the original which seems to have worked for now
  • fastbike1fastbike1 Posts: 4,083
    That's where they are supposed to load (i.e. the path is the zip file). Both UHT2 and UHT2 Fantasy load in the same folders.
    The problem is, they won't if you've installed using Connect — the way Connect works, it installs each product into its own content folder. Install using DIM and it will work.
