Looking for a lei
WillowRaven
[Looking for a lei] You, know ... one of these:
https://www.bing.com/images/search?q=lei&FORM=HDRSC2
preferably a posable one, but any ideas would do ... or maybe a good idea as to how I'd Frankenstein one myself?
There is a hair that came with Kalea that I think comes with a plumeria flower? You could put in a bunch of those around a character's neck. It's called oleander, but it looks more like hibiscus to me. That might do ya.
https://www.daz3d.com/oleander-hair-for-genesis-3-female-s
there ae these but they are cartoons
https://www.daz3d.com/gumdrops-leilani-the-hula-girl
https://www.daz3d.com/koshini-clothing-pack-3-island-girl
Ken Gilliland at Hivewire has some Hula sets with a Lei included
Aren't we all. sigh.
My immediate response outloud to my empty place, LoL!
Found the one I used in this image at contentparadise a couple of years ago.
Think it was called Hula (something) and was for Aiko 4.
Not in my R/T any more but could scratch round my archive drive if it's of interest.
I made one from SAV's (Renderosity) poseable Boa; I replaced the feathers with flowers. Just take some diffuse, bump and transparency maps from another pack (in my case it was Faveral's Hazienda Hermosa) and adjust them. There is a Boa in the Daz shop https://www.daz3d.com/boalicious-poseable-feather-boa-superpack
You could try the operation with this model (it's only $ 2.99 for PC members), but I don't know if it is possible.
That one is definitely of interest. Not as cartoony or fake looking as most I'm seeing.
Edit* I found it ... Hula Dancer ... thanks :)
That's gorgeous ... How hard would it be for me to convince you to make one in red-white-pink-white colors?
Sorry WillowRaven, this is impossible - unless you own the products I used.
But even then I don't know if it is allowed to give away a texture, i.e. a 'new product', I made from those two... But this kind of 'advanced kitbashing'
is much fun; I could tell you step by step how to do it (it is really easy!) and give you the parameters of my own lei.
I'm sure a tutorial would be enjoyed by more people than just me :D
Well, I'll try...
As you can easily see, English is not my native language, so there will be some mistakes , but I hope I can make myself understood. Give me a few minutes, okay?
Actually, I wouldn't have noticed, and I can usually tell since a lot of my authors are foreign. You write English well.
Ah, thank you (blush)!
Here is my attempt to write a tutorial:
Turn a Feather Boa into a Lei in DS Studio:
(I'm from the Stone Age, still using DS 4.6, but I hope it also works in DS 4.8/4.9)
++ Install https://www.daz3d.com/hacienda-hermosa (though it is an older product I promise you won't regret buying it) and studioartvartanian's (SAV) 'Feather Dreams' (also highly recommendable; it's from this other shop ;-))
++ Go to 'Figures' in the Poser Formats, find the SAV -> FeatherDreams folder, and load '2ndShoulderFeatherB'. This one is very easy to pose.
++ From now on you will only need to work with the Surface tab. Here I used Flower No 2, but of course you can take any other flower of the 'Hacienda'. To get the results shown in my picture above, select the boa and open the Surface tab. Click 'Feathers', and then 'Browse' in the little window on the left of 'Diffuse Color'. When it opens, go to: DAZ 3D -> Studio -> My Library (or My Daz Library) -> Runtime -> textures -> Hacienda ->HH-Flower2.jpg. The feathers of this part should now show the colour of the flower.
++ Now your flowers need the right shape. Click the Opacity Strength window in the Surface tab, then 'Browse', and follow the path to HH-Flower2T. Take this transparency map, but you can also use HH-Flower1T.
++ I set 'Glossiness' (a very important parameter; I don't understand why so many PAs remove it in their products if they sell 3DL Materials together with Iray Mats) to 50%, Specular Color to 207-139-163, Specular Strength to 100%, and Lighting Model to 'Metallic', but this is optional. Play with these parameters until you have the look you like.
++ You can also add something like a Bump Map. Just click the little Bump Strength window, and select the diffuse map HH-Flower2. I set Bump Strength to 100%, Negative Bump to 0.080, and Positive Bump to 0.18. (Almost) ready!
++ To turn the second part of this boa, 'Feathers2', into flowers, click 'Feathers', and go to Edit -> Copy -> Copy Selected Surface in the top menu. Select 'Feathers2', go to Edit -> Paste -> Paste to Selected Surface(s) and click. Now your Lei is ready!
++ If you want to mix red and white flowers, the simplest way is to remove the diffuse map from 'Diffuse Color' of one of the two parts. If you remove the diffuse map from 'Feathers', you'll get more red flowers, as 'Feathers2' seems to be the bigger part. Check the specular color, and make it darker it if the white flowers are too white.
++ Finally, to become a 'real' Lei, the boa should be posed. It has 10 sections at each side, plus a 'StartPoint' in the middle of the neck. Move the sections to your liking ('Parameter' tab), and close the lower ends so that the figure forms a ring. Make the lower sections invisible if the Lei is too long (see pic). Of course it is best if you do the posing when the figure is wearing the Boa/Lei.
Tell me if this little tutorial works, and if you need more pictures!
Great use of resources caravelle. Looks good.
Hunted out the zip for the one I have and reinstalled it. If I was going to use it in a render I'd do new textures for the flowers first.
Had a play to see if I could get a better result then previously. Tried sub-D on the core but that choked my poor old i7 4770.
Did two renders of the flowers in different colours and composited them. Thinking caravelles system's looking to give better results.
Imagine it'd be more versatile posing as well.
If you want to get lei-ed for free, try this: http://www.sharecg.com/v/67195/view/5/3D-Model/Hawaiian-Lei
This is coming late, as I just found this thread but still: Caravelle, a big thanks! The only other good looking lei I found was at turbosquid, non poseable and damn expensive :) your solution
is great!
