TangoAlpha's Coming Soon Thread [Commercial]
191012141522
    edited May 2017
    I did a render of Howie's Forest Drive at the same resolution, and that rendered in 204 minutes (3 hours 24) - see the renders thread. That scene is probably of similar replicator density although a lot more leaves, so I'm happy that my set is not abnormally slow at rendering.
    Post edited by TangoAlpha on
  • DiomedeDiomede Posts: 15,401
    Yes, given the complexity, I did not think the render time for the ford scene was odd.  I was sort of expecting it given my experience with Howie's scenes.  Both yours and his are worth the time, but I would be happy to hear of strategies to lower the render time.  Also, I am very interested now in the Daz Studio default render time for 3DL.  I don't suppose anyone has tried the bridge from Studio to Bryce?  Would the instances transfer?
    I have no idea about Bryce, sorry.
    I know nothing about the bridge.      However I somehow doubt that the instance would transfer.     Bryce instances work completely differently to D|S  instances.
    edited May 2017
    Maybe they would need to use the ford instead.
    Post edited by Chohole on
    Did a quick test of the bridge from Daz Studio to Bryce.  Not surprisingly, Chohole is correct.  The instances did not transfer (or I did not know how to activate them or look for them).  The terrains did in a low resolution way.
  • DartanbeckDartanbeck Posts: 21,988
    One great place to start is to look hard at shaders. In large, intensive scenes like this, here's where I start:
    Tree leaves - is there a translucency? If so, getting rid of that can make a huge difference.
    While we're on leaves, is there an image in the Alpha channel? If so... perhaps replacing the leaves with any of those from the Carrara library would help. Trans-mapped leaves can realy slow things down in large scenes.
    Water - in this case, I think I'd want the higher-quality water with refraction. But if you don't care about refraction, try turning that option Off in the Render room and leave the water shader's refraction setting alone for now. Are there any blurry reflections? Are reflections too high?
    Volumetric Clouds can really tax a render. Disabling them completely will speed things up. But if you really like them, try making sure that you have a Sun Light in the scene, then edit the volumetric clouds to "only" use the Sun Light.
    Check all of the lights' "Effects" tab for Soft Shadows. Turning those off will make a HUGE difference and, in many cases with Large scenes, won't make a bad render. If soft shadows are really needed, try using a light dome with around 88 lights without soft shadows. According to Tim Payne, reaching around 88 lights will cause the hard edges to naturally form soft shadows on their own.
    Light through transparency is a big one in Carrara. Try eliminating as much use of trans maps in the alpha channel as you can. Transparency with Reflections and Refraction will also cause for a lot of calculations. If we need this stuff, try turning the max ray bounces down to 2 in the render room and se what that does. Sometimes it can really speed things up, but without enough iterations of reflected light (folks call it bounce) might look like ick in the end. It can be a trade-off sometimes.
    Do remember, however, that: if there IS translucency On in the leaves' shaders, it WILL make an appearance difference in the render by turning it off. In these cases, using what is often called Bounce lighting can help to counter this. Try a Distant light set at a dark hue of green (or whatever the translucency color was) and then still keeping the brightness of the light low, say 6 or even less, turn off shadows and point it upwards and away from the direction of the camera - to add a subtle illumination to the underside of everything facing the camera. Sometimes it's prudent to add a couple more at even lower levels of brightness.
    edited May 2017
    Yes, the tree leaves have translucency, as do some of the flowers. Cos they look ----ing awful without, IMHO.
    No alphas in the trees - all my leaves & flowers are geometry. I learned how slow transmaps get very early on. Some of the weeds (dandelions, butterbur) are transmapped, but they add very little overhead.
    The water shader does make a difference, according to my test a few posts up.
    I Don't use volumetric clouds. My scene is set up with Realistic Sky. The Sun does have soft shadows set. I did a comparison of this against a "fake GI" dome rig some time ago, and there was very little time difference, frankly.
    I do have light through transparency turned on. Playing with that might make some difference, and the general fidelity settings too.
  • StezzaStezza Posts: 8,881
    Great tips, I'm on me iPad at the moment but yesterday I did get the render time to under 21 minutes on the default camera 3 scene thinking that it may be similar as Howie's setup.. today I'll try some fake lighting as Dart suggests to fine tune it and post my result later in the day... gotta have brekky now and watch the morning news to make sure we are all still here... angel
    edited May 2017
    Managed to get the default scene rendered in 4 minutes ... happy with that smiley
    1280 x 720 - 981K
    Post edited by Stezza on
  • ProPoseProPose Posts: 547
    This one rendered in Carrara 8.1.  Camera 3.  Just over 35 minutes with the default render settings
    1280 x 720 - 969K
    No clue about Bryce either, but I tries and this is what I ended up with
    1754 x 885 - 428K
    Actually I kinda like that smiley
    edited July 2017
    In case you wondered whatever became of Guantomato bay . . .
    "Containment Level" coming soon for Carrara and DS smiley
    1920 x 1080 - 2M
    1000 x 1300 - 761K
    1000 x 1300 - 817K
    1778 x 1000 - 993K
    1778 x 1000 - 914K
  • PhilWPhilW Posts: 5,162
    edited July 2017
    An amazing set! (Another!)
    Post edited by PhilW on
  • Bunyip02Bunyip02 Posts: 9,290
    Looks great.
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Glad it didn't go to waste. smiley  Looks awesome!  This set is a great compliment to Crime Lab.
  • SileneUKSileneUK Posts: 1,977
    edited July 2017
    Ah, now I see the common thread running through your scenes... they drank too much cider, now they are truly contained after morphing into 'them'... and some will end up on the autopsy table, but their solicitor will demand a day in court for the rest, after which they will take their compensation to the bank, but keep enough to open a club and, then become patrons of the local theatre where their odd appearance will be a hit on stage in the musical, Last Tango in Alpha. Now they can afford a  medevial castle place in the country, and survey the countryside from horseback, riding in the fields and fording every stream with the day ending at the top of the folly!
    More cider please!
     cheeky Silene
    Post edited by SileneUK on
    More cider please!
     cheeky Silene
    Brilliant!
  • VyusurVyusur Posts: 2,235
    Beautiful and scary scenes. The set reminds me of Resident Evil.
    edited July 2017
    Zombie Ed . . . (and possibly a clue to the movie that inspired it) wink
    2550 x 1080 - 2M
    How did you achieve this volumetric light effect? I can't get the desired effect in iray.
    I made an SSS fog box, as per this tutorial
    I left the lighting as normal (emissives on the fluorescent tubes) and tweaked Transmitted Measurement Distance and Scattering Measurement Distance to somewhere around 300. I think the optimal number depends on how big you have the cube primitive. Lower is more foggy.
    BTW, the murky water effect in Country Ford works on the same principle.
  • HeadwaxHeadwax Posts: 10,458
    you might have Donald Trump Chasing you next, nice work, looking forward to it
    Another excellent set.  And thanks for the link to the SY fog box tutorial.
    TangoAlpha, thank you for the great tips and tricks. I've already seen this tutorial but never tried to repeat this in DS. But I used the same technique in Carrara and it worked well for me.
    edited July 2017
    Just to keep you anticipating . . .wink
    1920 x 1080 - 1M
    edited July 2017
    https://www.daz3d.com/containment-level ;smiley
    (and the rest of my store is 40% off too)
    Are the zombies the good guys or the bad guys?  laugh
