Moisture on Surfaces in iRay
In iRay, if I wanted to make a wet rocky surface, how would I go about that?
Like this: https://c1.staticflickr.com/9/8037/7972629846_b0999c230d_b.jpg
  • AndySAndyS Posts: 1,449
    You can basicly do it with corresponding glossy parameters directly.
    Or you use the topcoat section.
  • JimbowJimbow Posts: 557
    Try these:
    Select the object and go to Create>iray Decal Node. In the decal's properties change the Face Mode to 'Front And Back', and Projection Type to Cubic. Scale the decal node so that it's bigger than the object. Then go to the Surfaces tab and select both the Front and Back surfaces and add one of the Liquid Water shaders.
    Another option is to use the Top Coat layer, change the Top Coat Layering Mode to Fresnel, make the Refractive Index 1.33.
  • BomberBomber Posts: 126
    Thanks guys! I'll try those!
    Bear in mind that rock can be porous and darken where it's wet. You might need to darken the diffuse colour.
    That's okay! I was hoping to get this effect on streets and food too. It'll differ for every obect.
  • RuphussRuphuss Posts: 2,631
    Jimbow said:
    Try these:
    thank you for that
    now i am having a new toy to play with
    iray decal nodes
    does it work like just one big geoshell ?
    edited April 2017
    Kind of. You have no option to switch off individual groups of surfaces, but they pick up the underlying bump and normals while overriding the underlying glossiness, etc. You can also limit them by translating and scaling the decal's bounding box. They can also use the object's UVs instead of the usual projections, but they will place the decal across the entire surface so you need to experiment. You can use cutout to stencil them, so if you had a generic dirt shader you could use speckles and scratches cutout maps, etc, to add dirt across an entire object.
    What I also do at times is apply a decal to a geometry shell with individual surfaces switched off where I don't want the decal to show, and make the geometry shell surfaces completely transparent.
    Post edited by Jimbow on
