how to adjust skin color for Brittany (genesis 3)
Is there a way to make skin tone lighter on a Brittany for Genesis 3? Mine seems to have very tan skin and I'd like to lighten it... I looked in the store for skin tones - would I have to use some skin shader for that? Below is what I have right now... any guidance would be much appreciated. Thank you
  • Richard HaseltineRichard Haseltine Posts: 111,721
    Does the character come with settings for different translucence levels? if so, the lower option will usually be lighter (more light bouncing off the skin instead of being absorbed/scatterd, though it will also potentially take light out of shdowed areas due to the lack of scattering)? Another, crude, option is to select all surfaces with the same diffuse colour/base colour map (you can do this with right-click from the Surface Selection tool), then in the Editor tab of the Surfaces pane click the mini-thumbnail for the Diffuse/Base colour, select layered Image Editor, apply a new solid colour layer, make it white, and lower its opacity way down; repeat for the other skin maps.
  • thanks, there is a medium translucence option, I'll try that one and your other suggestion. thanks again
