On the Transfer/Autofit utility and Hair and Bulge Weights
wancowwancow Posts: 2,708
I just found out something interesting. I was trying to get the Yoanna hair to work properly and I found out it has NO bulge weight mapping applied.
If you are having trouble with your hair converted from V4 to Genesis, try going into the Weight Map Brush, and copying the weight maps from the joint rotations to the Bulges... see if that doesn't help. Sure made a difference on the Yoanna hair.
    Interesting...thanks for letting us know.
  • wancowwancow Posts: 2,708
    It doesn't seem to work on everything, but I also used it on the Summer Hair (that's at DAZ) and that DID work... same exact thing.
