mcjEgg - Egg prop - 2 pieces but looks un-broken when closed - UPDATED!
https://sites.google.com/site/mcasualsdazscripts8/mcjegg
a poser prop but since the .obj files are standalone, it can be used anywhere ! about 3K polys
get version B it's very much easier to resize without losing the match of the 2 pieces ( resize the bot and top parts, they have their origin at 0,0,0 )
https://www.daz3d.com/forums/uploads/FileUpload/44/f75c1375b8c4ed6a421fdd63770929.jpg
Post edited by mCasual on
Nice one.
Is it Easter or something?
there's rumours to that effect
then again, it could be a riddle in a riddle in the form of an egg
not an easy one to crack
Batman: [thinking out loud] Apples into applesauce - A unification into one smooth mixture. An egg - nature's perfect container. The container of all our hopes for the future.
Robin: A unification and a container of hope? United World Organization!
thank you again for this very nice idea of a prop jaques
how do i use one texture fitting to both parts but look as one ?
and i very much like your small video clips
the UV map is a cylindrical projection and was created while the pieces were combined
the eggTop fits perfectly with the eggBottom
unfortunately you have to do it by hand, but after that, apply the same image to both pieces and it should be seam/crack/less
i will post an update this morning, also because the prop has the remnant map from an iRay shader on it
thank you
and ok i got the texture thing
now I need an animation from crouch to stand and cheer for Gen2 fem/male
i will try
Update Update Update
mcjEggB a version that is wayyyyYyy easier to resize ( while keeping both pieces together
for your last-minute Easter renders
Thank you and Happy Easter
