mcjEgg - Egg prop - 2 pieces but looks un-broken when closed - UPDATED!
mCasualmCasual Posts: 4,607
edited April 2017 in Freebies
https://sites.google.com/site/mcasualsdazscripts8/mcjegg
a poser prop but since the .obj files are standalone, it can be used anywhere ! about 3K polys
get version B it's very much easier to resize without losing the match of the 2 pieces ( resize the bot and top parts, they have their origin at 0,0,0 )
https://www.daz3d.com/forums/uploads/FileUpload/44/f75c1375b8c4ed6a421fdd63770929.jpg
960 x 960 - 316K
960 x 960 - 171K
800 x 800 - 189K
960 x 960 - 128K
960 x 960 - 159K
800 x 1232 - 100K
Post edited by mCasual on
  • nicsttnicstt Posts: 11,715
    Nice one.
    Is it Easter or something?
  • mCasualmCasual Posts: 4,607
    there's rumours to that effect
    then again, it could be a riddle in a riddle in the form of an egg
    not an easy one to crack
    Batman: [thinking out loud] Apples into applesauce - A unification into one smooth mixture. An egg - nature's perfect container. The container of all our hopes for the future.
    Robin: A unification and a container of hope? United World Organization!
    nicstt said:
    Nice one.
  • RuphussRuphuss Posts: 2,631
    edited April 2017
    thank you again for this very nice idea of a prop jaques
    how do i use one texture fitting to both parts but look as one ?
    and i very much like your small video clips
    Post edited by Ruphuss on
    edited April 2017
    the UV map is a cylindrical projection and was created while the pieces were combined
    the eggTop fits perfectly with the eggBottom
    unfortunately you have to do it by hand, but after that, apply the same image to both pieces and it should be seam/crack/less
    i will post an update this morning, also because the prop has the remnant map from an iRay shader on it
    960 x 960 - 699K
    thank you
    and ok i got the texture thing
    now I need an animation from crouch to stand and cheer for Gen2 fem/male
    i will try
    edited April 2017
    Update Update Update
    mcjEggB a version that is wayyyyYyy easier to resize ( while keeping both pieces together
    800 x 800 - 97K
    for your last-minute Easter renders
  • Faeryl WomynFaeryl Womyn Posts: 3,779
    Thank you and Happy Easter
