Finding Hidden Active Morphs- FIXED with Workaround
IceDragonArtIceDragonArt Posts: 12,972
edited April 2017 in The Commons
My Gen2Female base character is not loading character.  I'm guessing this means other morphs are loading, however, I can't find them.  I know there is somewhere I can ask to display all active morphs but can't remember how to do it.  And I have far too many to scroll through and try and find them that way.
  • fixmypcmikefixmypcmike Posts: 19,709
    edited April 2017
    From the options menu make sure 'Show Hidden" is ticked, then click on "Currently Used."
    Post edited by fixmypcmike on
    edited April 2017
    Thank you.  Unfortunately that isn't finding enough to fix it. For some reason V6 is partially loading with the base Genesis 2 female which it has never done.  However, zeroing those out does not bring it back to the base female.  And when I try and apply a different character, the face distorts rather badly.  Haven't made any changes to her so not sure what is going on all of a sudden. I can zero the figure but I can't apply any other figure shapes to the zero'd figure, as it also distorts.
    This is what I have the base figure with the v6 zero'd out.  And then the base figure zero'd which looks like it should but won't take morphs correctly.
    1236 x 2000 - 4M
    1236 x 2000 - 4M
    Interestingly, I can dial a character in once I zero the figure but I can't use the preset actors or one click shapes.  Might just have to uninstall and re install and see if that fixes it.  Not sure where else to look.
    If you zero the figure and then look at Currently Used, does it show anything?
    yes, it shows Stacia but both head and body at zero%.  When it loads from the original icon it show V6 head at .50 and body at .36.  When I zero the figure that goes away and is replaced by Stacia head nad body 0.00
    edited April 2017
    I should add that I do not have a Stacia character for Gen2f....Yet if I move the Stacia sliders to 1 it becomes the shape and face that loads when I load g2f
    Locking the Stacia sliders allows me to use my other characters correctly.  So its clearly those two morphs.  But I can't find them anywhere to be able to uninstall them. I haven't purchased or loaded any new characters for G2F and can't find the morphs in my files either.  They are clearly there but I don't know where lol.
  • RedzRedz Posts: 1,459
    edited April 2017
    Take a look in the Stacia parameters by clicking the gear icon. If the default value is non-zero, then that is the issue. If so, you can load G2F in a new scene, set the Stacia default values to zero (in the parameters and the sliders) then save as - support asset- save modified assets and G2F should load without the morphs on by default.
    Post edited by Redz on
    Ya that is definitely the issue as they are loading at full Stacia.  Whomever that may be lol. I sincerly have no idea where that is coming from.I don't have a G2F character names Stacia and its weird that it would just all of a suddent load it.  Will give your solution a try.  I am also going to continue to go through my morphs files behind the scenes and see if I can find it there as well.
    You're not the first to encounter this, from this thread she was a freebie at some point by FWSA, might help locating the stacia morphs in your data folder
    http://www.daz3d.com/forums/discussion/53192/stacia-morphs-load-with-other-characters
    Ya that is definitely the issue as they are loading at full Stacia.  Whomever that may be lol. I sincerly have no idea where that is coming from.I don't have a G2F character names Stacia and its weird that it would just all of a suddent load it.  Will give your solution a try.  I am also going to continue to go through my morphs files behind the scenes and see if I can find it there as well. And thank you for the link as well it was most helpful.
  • Pack58Pack58 Posts: 750
    Try: (relevant R/T)\data\DAZ 3D\Genesis 2\Female\Morphs\FWSA\Stacia
    I will try that @Pack58 thank you.  Interestingly enough when I do a search for Stacia on my laptop for both my E drive and my C drive, it find nothing.  No mention of stacia anywhere.
    Well that folder does not seem to exist anywhere.  Its like a ghost....
    I just zero'd the figure out to the base female and saved as a figure asset.  That seems to be working fine.  I would still like to track down those elusive morphs but my computer literally tells me there is nothing labelled stacia anywhere on it.
  • Somehow the Stacia problem has worked its way into my system again.  Still can't find any files about her.
