Salsa skirt - poser file not found
Pinzelmeister
I have a clothing set I'm trying out. All items in the set work except this one (the skirt) - I'm looking for help understanding the error message I get when I try to load it. I have the "cr" file, but DAZ says it's looking for an obj file (??) I have no idea what this implies/where the file might be since I don't even have a F\Poser Archive\ etc. Suggestions please? (I realize part of the problem is that I don't understand the relationship between "cr" and "obj" files . . . on the other hand, all the other items in the set seem to work fine).
The first thing to tell you is this, The CR2 (character) file is looking for the OBJ (mesh) file to load it first. DS is looking for it, where the CR2 file tells it to, in F\Poser Archive\Poser4\Runtime\Geometries, which is where mesh files (OBJ) would be stored.
Where did you get this item from? If it is a freebie, then it has not been set up correctly, and the path to the OBJ file is probably what the original creator had on their machine. You could do a search on your machine for the OBJ file to find out where it really is, and edit the CR2 file to give the correct path. CR2 files are text only files, so any text editor will do.
Thanks - that seems to have worked. 1) Made copies of the cr2 files in a separate folder. 2) Opened them in Word . . . compared the text. 3) Fixed the path in the skirt file to look like the others (i.e. point to the correct folder for the obj). Saved it, tried it out . . . success.
Something to note when fixing this kind of problem — Poser figure files that call for an external .obj file do it on two lines up near the top of the file. Prop and non-figure hair files will only have one line up near the top.
