White showing up in Transparent Hair
When I go to render my figure in Iray, a white background appears behind the hair. Can anyone tell me whats causing this?
  • Richard HaseltineRichard Haseltine Posts: 111,482
    This is a known issue with iray - you have a light behind the figure, Render Emitter is set to Off but it shows behind the hair. The fix is usually to adjust the placement of the light and/or the camera angle to avoid the issue.
