SOLVED: Where is the option to subdivide located?
Serene Night
Hi:
I have looked but can't seem to find the place where I can apply dubdivision. I bought Worldbase XT and one of the sections Worlbase XtrRings has lines when using uber environment lights I was advised to subdivide this section, however, I don't see this option under surfaces. Can someone tell me where it is located?
I appreciate the help.
Select the item...then Edit > Object (or Figure...depending on what it is) > Geometry > Convert to SubD
Hi...
With the item selected go to the scene tab, options menu -> Edit > Geometry > Convert to SubD...
Hope this helps... :)
Hehe, interesting. I always went to the little menu off of the scene tab after selecting the item, then edit, convert... didn't even realize it was in the menu ;p
Thanks everyone! that really helped get rid of the gridlines.
