Do figure/prop files [dsf and duf] contain mesh info?
patience55patience55 Posts: 7,006
Just curious at this point. Because in creating them I start with an .obj and so eventually might need to know does the .obj need to be included in the share.
Thank you.
    The dsf file written to the data folder is the geometry...
     "file_version" : "0.6.0.0",
     "asset_info" : {
      "id" : "/data/mjc/thshirt/tshirtlo/tshirt.dsf",
      "type" : "figure",
      "contributor" : {
       "author" : "mjc",
       "email" : "",
       "website" : ""
      "revision" : "0.0",
      "modified" : "2012-10-29T03:31:09Z"
     "geometry_library" : [
       "id" : "tshirt-1",
       "name" : "tshirt",
       "type" : "subdivision_surface",
       "edge_interpolation_mode" : "edges_only",
       "vertices" : {
        "count" : 254,
        "values" :
    It also contains the groups, weightmap data, skeleton, materials and so on...
     "asset_info" : {
      "type" : "figure",
      "contributor" : {
       "author" : "mjc",
       "email" : "",
       "website" : ""
      "revision" : "0.0",
       "id" : "tshirt-1",
       "name" : "tshirt",
       "vertices" : {
        "count" : 254,
        "values" :
    Okay, great. Thank you.
    Yeah, it packs the geometry for you. You don't need to include an .obj unless you're especially trying to target the 3DS Max etc. customers (I think Rendo has that category).
    Good point.
