Dear KindredArts....
2»
  • KindredArtsKindredArts Posts: 1,335
    fastbike1 said:
    I apprecaite the responses. I'm now fairly sure something was glitchy with my first few tries (all with the same Studio instance). I'm getting results and just need to get more familar with the product. I'm going to quit posting here since the other thread is active and I'm getting a handle on using this product.
    FWIW, I don't typically use camera presets. I assumed that this product would at least produce something by just loading a HDR. As I said, it appears to do just that (now), so I think I had some temporary glitch with Studio.
    I'm not sure what was going on. I can get a planet to show up now. Render in the other thread. I still have questions about getting "close up" renders similar to some of the promos (other thread). I was definitely frustrated because I typically don't have trouble getting a basic render on the first try, and definitely not with an empty scene w/ HDRI. Also haven't had problems w/ your products, so was definitely frustrated.
    I have a vision of Bastion w/ DarkEdgeDesigns new SpartechOps.
    Thanks guys, i appreciate it :)
    @fastbike1 - I'm over in the other thread answering questions. For some of the hdri's i used a really low yield star map which doesn't show at all at lower exposure values. I was trying to stay true to source. Again, i'm in the other thread for support, or you could pm me if that's any better.
    I'm sorry you're having trouble, and i agree i should have included some camera presets, it just didn't cross my mind at the time. I've replied to you Re: Camera settings in the other thread. Either lowering frame width or upping the focal length should limit the field of view thus bringing more of the planet in view. If you could do this in iray interactive view, that would be better. Let me know if this helps and if you need any further assistance. Cheers!
    No problem, it could have been a bug of some sort. You seem to have it under control but i'm always around the forums so just give me a holler if you have an issue.
  • exstarsisexstarsis Posts: 2,128
    The pretty blue galaxy, but pointed at the less galaxy part. The near star  makes a good moon!
  • FeralQuokkaFeralQuokka Posts: 81
    edited April 2017
    Kindred Arts, the Iray HDRI Space was a zero-day purchase. Awesome product! I cross my fingers in anticipation of any more expansions you might create, especially with gas giants or other stellar bodies.
    In this image, I rotated the HDRI about 190degrees and threw in a point light to highlight the ship a little more with some playing in the tone & ISO settings.
    Arachnid blues
    Post edited by FeralQuokka on
  • nonesuch00nonesuch00 Posts: 18,795
    Do these render at 4K (you know the biggest preset size in the DS iRay Renderer settings)?
  • Do these render at 4K (you know the biggest preset size in the DS iRay Renderer settings)?
    The HDRI maps are: 8000 x 4000 to 16000 x 8000. I normally render at about 4k settings depending on the job or need... and system limitations.
  • SimonJMSimonJM Posts: 6,076
    edited April 2017
    Here's my first use of one - and by the way, whoever mentione trhe idea of the mirror ball to get an idea of what the HDRI is like is a star!!!  Also starring is AntFarm's new Roamer and the Astra spaceship
    As a side note, that took 44 seconds to render smiley
    1500 x 1200 - 1M
    Post edited by Chohole on
    Cool render SimonJM, I pity the poor droid hoping for pickup.
    Great renders coming in guys, glad to see it in action!
    Yes, you can render in 4k. Render size is more a limitation of your hardware rather than hdri size. There are sizes up to 16k which is enough for a straight viewing angle at 4k without losing much fidelity.
  • greymouser69greymouser69 Posts: 501
    edited April 2017
    Started a test last night and let it run all day while at work, just an old stonemason set (skyline hall) and beo2k10.  Set all the surfaces shader to Iray Uber Base then made 3 (light, red led, blue led) emissive with Real Lights for Iray and rotated the HDRI to -70.on the Iray asteroid field orange preset.  Stopped at 22% after 18.5 hours so still grainy, CPU only.  Not entirely happy with it quite yet.
    spaceHDRI
    1024 x 768 - 1M
    Post edited by greymouser69 on
    spaceHDRI
    Great job mouser! You could probably even do a bit of contrast work in post and call it a day. There's a perfectionist in all of us though, i get it. wink I would advise bloom and lens flares but i always get shouted at for relying on them too heavily .. just biased i suppose.
  • Typically I would render at 2x my desired end resolution then down sample in Gimp after "finishing" to polish it up some.
    Same. I've tried some noise reduction software, since even complete renders can have a bit of grain here and there. I find a lot of packages tend to strip away detail though, so i just go for downsampling if i have the GPU budget.
    One day I'll pick me up a NVIDIA based system, but for now I'm AMD & ATI strictly.  I don't mind the hours because I remember rendering with bryce for 3+days on some images.
  • Digital Lite DesignDigital Lite Design Posts: 728
    edited April 2017
    These are awesome!!
    Ok, the squirrel in space....ya, there's a story there.  :)
    1074 x 1374 - 835K
    Post edited by Digital Lite Design on
    These are awesome!!
    Great render Kat! I kinda feel sorry for the poor chap though sad The light going through his fur is quite enchanting. Here's hoping he gets his nut yes
  • KnittingmommyKnittingmommy Posts: 8,191
    These are awesome!!
    That's adorable!  I love that one!
  • TaozTaoz Posts: 10,286
    These are awesome!!
    Watch the new movie "In Search of The Lost Acorn"...
  • :)  Thanks!  All the pieces were fun to work with.  AM's squirrel is a blast and I LOVE these HDRIs!!  :)  Tho I still need to figure out how to position them right.  Fitting the helmet and space gear on a squirrel gave me less trouble.  LOL  But I'll get it!  :)
  • IceDragonArtIceDragonArt Posts: 12,922
    dreamfarmer said:
    Heh heh heh. "Outer space." (Same HDRI as the above.)
    Well that's a good idea! Which hdri is that?
    LOVE this Dreamfarmer!
    More, more, more!
    The truth is, I've had a space opera setting on the back burner, and I refused to let myself engage with it until I felt I'd fulfilled my commitments to other worlds (2 books in one pentology done, 5 books in one.... endless... series done). But I've wanted to, more and more. Incidentally, I have an autistic son who loves space and planets. So it went like this: I saw the set. I thought, "I have to show my kid. I'll have to buy it and show him. I'll have to buy it and make space renders.... aieeeeee" and then I fell into the event horizon of my space opera.
    More, more, more!
    Great render DF! I saw this on DA but i didn't make the connection with your name. I'm glad he likes space, i'm a space nut too. smiley
  • I love the promos for this product, but I can't get it to work.  The DIM indicates it was installed but I have no idea how to set the hdri or where to find them to set them as an environment map myself D:  nothing seems to appear under the smart content under environments or even light sets, but I tend to stick to files over products if that's the easiest way to get to them.
  • scorpioscorpio Posts: 8,533
    You should find them under
    Render Presets>KindredArts>Iray HDRI Space
    edited June 2017
    I can't really help with DIM, i don't use it. The lights should appear in the following directory though - My Daz3d Library/Light Presets/KindredArts/Iray Space. Once you double-click one of the render presets in that folder, it will change your environment settings and apply the corresponding HDRI. If you want to use DIM i might have to reel in help to get you sorted, but if you want to install and use them manually, i can walk you through the process.
    Edit: Or what scopio said above
    Post edited by KindredArts on
    Thank you, this is where I found them.  At least I don't feel shafted for buying them now but an option under the smart content pane would be nice.  Now to figure out how to actually set them.
